Gear Discussion Forums => Bill's Shop: Projects, Mods & Repairs => Topic started by: drbassman on July 07, 2010, 06:27:34 AM
The mudbuckers from my EB-3L were rewired for a bunch of switches and coil tapping, etc., etc. I'd just like to return it to the original 2-wire set up. Anyone here who can help out? They work just fine but they each have like 4 wires coming out of them!
You mean both the mudbucker and the minibucker have 4 wires? That must be a custom pickup job. What color are the wires?
I wondered what all those switches were for! :popcorn:
The Dimarzio Model One in my '64 has four wires...I'll bet that if you check their wiring diagrams the four wires split out the same way.
Two possibly relevant documents:
http://www.dimarzio.com//media/diagrams/4Conductor.pdf
http://www.dimarzio.com/media/diagrams/ModelP.pdf
Re your MB - sounds like Joe's coil tap type mod - you just need to make sure which "pair" go together and wire them in series - my only word of warning is re the output - the biggest surprise I had with mine was the significant increase in output when I reversed the phase of one coil from standard, so you may need to play her before you permanantly wire in - stock output was the quieter of the two...
Someone here will be able to let you know the standard resistance of the bridge pup and again I must presume that the wiring will be as above - in series and in phase...
Yeah - what Ken said.
Each coil in the mud measured about 15K, and when wired up stock with the two coils in series it measured ~30K. This was a late-60s version, but I think yours would be about the same. If you have some way of posting a picture of the business side of things I might be able to tell you what wire goes where.
The minibucker also has this? That's a new one for me, but same deal there I would imagine. I'm not sure what those should normally measure on a good day, though. Shows how much I value that pickup! ;D
On my original both white wires were paired and the only ones that came out to the connection point were black...
My original '67 minibucker measures 6.98k
Yes typical minis are on the 6,5k-8k range. Somebody did naughty things to this old lady!
OK, here you go. The pups each have 5 freakin' wires!! Help this poor woodworker, I don't want to have to send these out for surgery!
Might help to post some pics of the pickups? Could it be that these are after market and not original?
Doh! I forgot the pictures!!! Nope, these are genuine Gibson, just some Franekstein electrician got into them deep. Red, green, purple, yellow white!!!!! Yikes.
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3177.jpg)
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3179.jpg)
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3180.jpg)
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3178.jpg)
It's ALIVE!!!
It's ALIVE!!!
:D
No idea, I cut the little buggers out after only playing it once. I'm a minimalist, I just don't desire all of these switches. When I want variation, I spin the dials on the Mesa.
You could try this for the mudbucker:
(http://i87.photobucket.com/albums/k125/0chromium0/forums/eb0pickup1.jpg)
Basically:
- Connect the yellow and purple wires together
- Connect the white and green wires, and ground them
- Use the red wire as your output
I couldn't see a green wire on the mudbucker - so I'm assuming it might be ground... Also, I couldn't see the white wire very well, but I think its that one on the treble side of the neck coil. See if that meters out around 30K.
Unfortunately, I can't see where the wires terminate inside the minibucker, but try this same config and see if you get a 6-8K reading. Hopefully, they used the same color keying on the wires...
Oh- and I pity the foo' that coil taps the world's most tinny, brittle pickup! ;D
(http://i87.photobucket.com/albums/k125/0chromium0/forums/MisterT.jpg)
Me too, but combined with some mud may have some nice results! ;)
I should have taken this picture earlier. Here it is from the side. The green is grounded to the pup frame.
Ohm readings are: Purple and Red = 14.8 White and Yellow = 15.5
I'll do some measurements on the mini later tonight.
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3183.jpg)
(http://i2.photobucket.com/albums/y16/drbassman/72%20EB-3L/100_3184.jpg)
The third of your first pictures shows the white wires connected to yellow/purple - they would originally have been shorted together and left beneath the coils...
From the colours showing on the other pup, I would presume you could do the same on both - so this time, as per Joe... ;)
The darker side of Kenny would advise to ensure you reverse phase for some SHOCK AND AWE output... :vader:
Cool- those pics show everything. That diagram I posted above should work to revert the mud back to its original config. I'd expect to see a reading around 30K after connecting the wires as described, and measuring across the red (output) and the green/white pair (ground).
(http://i87.photobucket.com/albums/k125/0chromium0/forums/eb3-bomb-squad.jpg)
Are you going to try to restore the Varitone/choke setup?
Thanks so much for your help guys,especially Joe! I'll let you know how it works out!
I might try to do a varitone set up. I like the look of these..............
http://www.bigdguitars.com/varitone.html
Wow! Those have been reworked for sure ! must be so you can split coils. Kinda scary !
Yeah, Dr. Frankenbass was into these babies. I'll restore them to their former glory!
You know, you could build one of those for little money, components are about 6 euros (without the dialplate).
Following Joe's notes was easy - reversing an MB's phasing is >quite interesting - I'll post sounds (once I get past my current hiatus) on my PC posting...
