I bought this case, measured my bass (seller said was 15 1/@" at lower bout) my bass is 15 3/4" at that bout but my bass does not fit at all, he also said there seems to be some variation in EB-2 measurements over the years, both the 1966 and the 1970 measurements are the same in their catalogues. I'm trying to get the seller to let me reurtn it as I don't even think this is the right case, it's too long and even with no padding in the case my EB-2 would still not fit. Could this case maybe be for a Grabber as they were a little thinner at the lower bout (14 1/2") than an EB-2?
http://www.ebay.com/itm/Gibson-EB-2-Bass-Guitar-Case-circa-1970-very-clean-/272773048301?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=ASx9UpvDq2n0zNvRlmGEThscTE4%253D&orig_cvip=true&rt=nc
Ripper?
That was my first thought too, Grabber or Ripper but I just saw a late 60's Les Paul Bass case and it looks identical, I'm not sure how wide a Les Paul bass is though.
Ripper/Grabber/G-3 family.
I haven't seen many red-lined cases from later than '72. Could it be for a Les Paul bass?
It seems that there are a lot of Ripper/Grabber cases out there, many NOS. I bought one by mistake a number of years back. I really didn't fit anything else well.
Thanks everyone, the seller will take it back, it's a nice case too bad it doesn't fit.
Most Grabber/Ripper/G-3 cases I have are redlined. Perhaps even all. (I hardly ever use the cases and prefer gig bags - that is why I'm unsure.)
Quote from: uwe on August 03, 2017, 12:50:11 PM
That's interesting. I've mainly seen the red used from about '70-'72, maybe even into '73. Then the purple seemed to have taken over, and then the blue in about '76.
Both my '73 and '80 Ripper cases have red linings.
Quote from: Denis on August 04, 2017, 07:18:44 PM
How wide are your Ripper case at the lower bout?
Mine was purple..............
Quote from: bobyoung on August 04, 2017, 09:12:26 PM
Both measure 16.5" at the widest. The '80 is snug, but the '73 is a little loose at that end. Thinking about it, it could be that the '73 case isn't the original one.
Mine's yellow...but is smells like cat pee so it may have originated white ;D
That lovely fungus smell of old cases - has traces of incense, for the altar boy in you. 8)
