Main Forums => The Bass Zone => Topic started by: Dave W on February 20, 2017, 09:38:12 AM
Title: New from La Bella
Post by: Dave W on February 20, 2017, 09:38:12 AM
Gold alloy flats (http://www.stringsandbeyond.com/la-bella-gold-flats.html)
They sound good in the demo video. The downside (in the description) is that they may tarnish and need removal for polishing with brass cleaner.
Title: Re: New from La Bella
Post by: Granny Gremlin on February 20, 2017, 09:58:28 AM
I don't think it says you have to remove and polish periodically, just if it bothers you that they change appearance over time.  Kinda the same thing as nickel wound strings that develop a patina; not a problem tonewise, but some people may not like the look of it.
Post by: the mojo hobo on February 20, 2017, 03:11:24 PM
But it does say that:"Carefully remove your strings before cleaning".
Post by: Granny Gremlin on February 21, 2017, 07:35:19 AM
IMHO: disclaimer.
Post by: Dave W on February 21, 2017, 11:46:26 AM
Sure, it's a disclaimer, but there must be a good reason for it, since you don't see disclaimers for tarnish on stainless or nickel wrapped strings.
Post by: Granny Gremlin on February 21, 2017, 01:15:37 PM
SS by def does not tarnish (it will get dirty, but that's different).  Nickel just looks cooler with a patina and guitar players all know that due to it's extensive history in both strings and hardware in general, but tarnished gold looks like shit.  I really think too much is being read into this here, it's as simple as the company covering their ass before users complain after being caught by surprise.
Post by: Chris P. on February 21, 2017, 02:37:08 PM
At the NAMM I saw LaBella tapewounds with clear tape! They had some thin coloured wire going through the tape, like bits of cotton threads? I dunno.. hard to explain. Looked like basses with rope instead of strings.
Post by: Dave W on February 21, 2017, 10:50:43 PM
Quote from: Chris P. on February 21, 2017, 02:37:08 PM
Those could be their white nylon tapewounds, which are more clear than white, or what they call their gold white nylon tapes. Also could be one of their special editions.
About 15 years ago, Richard Cocco told me the strings inside their 60-115 black tapewounds were a 44-08 roundwound set. I unwound a dead set next time I changed strings on my EB-0L and measured them with my digital calipers. Sure enough, that's exactly what they were. Now they offer their black and white tapewounds in 50-105 sets too, so I imagine the inner strings must be very small, like 34-88.
Post by: Chris P. on February 22, 2017, 02:07:21 AM
It were specials.
Post by: hieronymous on February 22, 2017, 10:53:19 AM
I bought a set of the gold flats for my Duck Dunn Signature P - I haven't put them on yet, having a bit of maintenance done on the bass, planning to string them up when it's back:
(https://c1.staticflickr.com/4/3792/32929553311_4ee1c551c2_z.jpg)
I probably shouldn't have got them - I have a feeling my sweat is going to cause these to tarnish quick, hoping that they end up looking kind of like the pickguard. Also hoping that they are medium/high tension - I currently have DR Legends on there and they are pretty low tension, enough that I should really adjust the trussrod. I originally had GHS flats which were perfect really - should probably have left them on but I wanted to experiment...
Post by: Dave W on February 22, 2017, 12:30:13 PM
They should be about the same tension as the regular DTB flats, since weight determines tension and most of the weight is in the solid core wire. They should look good with that anodized pickguard.
It's been a long time since I had a set of GHS flats but IIRC the tension was comparable to the LaBellas.
Post by: Granny Gremlin on February 22, 2017, 01:09:51 PM
I hate to continue the trend of contrarianism here, but wouldn't tension be determined by a number of factors including density (of which weight is a factor) as well as the comparative torsional strength of different alloys?  Weight alone assume that the materials are identical (and though the core wire is probably so, we don't know that for certain, and the wrap will have some effect, I'd suspect above negligable, if not by much).
Post by: Dave W on February 22, 2017, 01:44:44 PM
Read pages 3 and 4: http://www.daddario.com/Resources/JDCDAD/images/tension_chart.pdf
I was referring to actual pounds of string tension, the pull on the neck, and that's what D'addario is talking about here. There are other factors that affect the feel of the string --  I think the correct term is compliance. One string may have the same or lower tension than other but feel stiffer.
Post by: uwe on February 23, 2017, 11:47:03 AM
"... may have the same or lower tension than others but feel stiffer ..."
That's my experience too. Mornings are best. Why not sail with the wind?
Compliance seems to be good term for it. I try to be all the time.
Post by: Dave W on February 23, 2017, 10:41:30 PM
Quote from: uwe on February 23, 2017, 11:47:03 AM
Do you spring back to the original tension afterwards?
Post by: uwe on February 24, 2017, 05:56:00 PM
More standby mode.
Post by: hieronymous on February 24, 2017, 07:13:40 PM
(https://c1.staticflickr.com/3/2612/32283898913_73aac73c3e.jpg)
Post by: 4stringer77 on February 25, 2017, 06:56:15 AM
Compulsory compliance is mundane. There can be no release without tension of course. That's why things are more interesting with some dissonance and contrarianism. Ok maybe that statement  doesn't apply solely to string construction.
Post by: Dave W on February 25, 2017, 09:49:19 PM
Some core wires are larger than others. And more rigid.
Post by: uwe on February 28, 2017, 02:43:14 PM
Roundwound inherent abrasion is not for everyone, some prefer the silky feel of flatwounds, others want coated action with their strings.
Post by: Dave W on February 28, 2017, 09:16:34 PM
Quote from: uwe on February 28, 2017, 02:43:14 PM
That depends on whether or not you play with a light or heavy touch. Stainless round windings are like little files. They can cause major owies. Best not to fret about it too much.
I don't like the feel of coated action, but it prevents unplanned accidents.
Post by: Pilgrim on February 28, 2017, 09:56:43 PM
There are also those of us with such lousy left-hand technique that when playing roundwounds, about every other time we move our hand, an obnoxious "zing" sound comes from the fingers moving across the rounds. Using flats solves this problem. If you have it. I'm just sayin'.
Post by: amptech on February 28, 2017, 11:01:50 PM
I like it flat and smooth on an average basis, but from time to time that 'ribbed and rough' feeling is just in Place - but With the risk of getting sore if you play too hard. It leaves you comfortably numb, so to speak.
Post by: uwe on March 01, 2017, 09:22:12 AM
Some people - even famous ones - say steaming your strings regularly helps. I guess that is hardcore advice.
Post by: Pilgrim on March 01, 2017, 09:28:45 AM
Steaming clams?
Steaming strings?
There's a certain symmetry there.  :rolleyes:
Post by: uwe on March 01, 2017, 12:14:06 PM
I wasn't alluding to that at all.  :-X
I hate that adolescent locker room innuendo some threads here are drenched with.  :-\
Post by: 4stringer77 on March 01, 2017, 12:15:16 PM
Well I better not mention anything about ernie balls then.
Post by: Pilgrim on March 01, 2017, 12:18:12 PM
I am shocked, SHOCKED to witness this adolescent locker room innuendo.
Especially when I don't start it.
(https://danieljmitchell.files.wordpress.com/2012/03/casablanca.jpg)
Post by: Rob on March 01, 2017, 12:55:32 PM
Quote from: Dave W on February 28, 2017, 09:16:34 PM
Just to refret more often.
Post by: Dave W on March 01, 2017, 05:32:36 PM
Quote from: Pilgrim on March 01, 2017, 12:18:12 PM
So... round up the usual suspects?
Post by: uwe on March 03, 2017, 09:30:58 AM
 :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Post by: TBird1958 on March 03, 2017, 10:14:10 AM
Is this part where I grab my ankles again   :-*
Post by: uwe on March 06, 2017, 08:53:12 AM
It'll be the beginning of a wonderful friendship, Mark.
