Gear Discussion Forums > Rickenbacker Basses
Removing pickup cover on 4001: grounding question
(1/1)
Denis:
Just removed the pickup cover on the 4001 and discovered it's plastic! It's a new replacement that came with the new pickup to replace the nearly dead original.
Question is, where does that ground go now that the cover's off? Can I simply run the screw through the pickup ring and spring, grounding it there?
Daniel_J:
--- Quote from: Denis on November 07, 2010, 11:40:18 AM ---Question is, where does that ground go now that the cover's off? Can I simply run the screw through the pickup ring and spring, grounding it there?
--- End quote ---
Yes.
Denis:
Thanks, got it! Much easier to play with that cover off!
Dave W:
BTW, the pickup covers have been chromed plastic almost since they were introduced.
Navigation
[0] Message Index
Go to full version
