Author Topic: The Peavey T-60 and T-40 story, with a lot of help from Chip Todd.  (Read 10463 times)
FlatEric
    • Flat Eric's Collection
Re: The Peavey T-60 and T-40 story, with a lot of help from Chip Todd.
« Reply #30 on: June 12, 2013, 05:06:50 AM »
Hi - Me again!
Just popped in for lunch, as it's been some time. . . .
Hope you are all well! :)
Just read in "Other brands" about the pawn shop T-40, although
I can't see the pics, :(
It also included the "Boat anchor" reference - Tank, is another one.
Yes, these are a little on the weighty side but are very well balanced.
I have a few "Divers" but only really as a collector, they are not easy to play
comfortably.
Anyone here got a Thunderbird type bass?? - OK, OK - not all at once! ;D
Most of you, then!
I have a good friend who plays a T Bird - just under 10lbs!
He does, however, rest his arm on the body, to balance it (he does the same with
an Explorer type) and just for a laugh, I said - take your forearm off it and don't
"hold up" the neck.
Now play.
Mmm, not so comfortable!
Then, I tied a cord on the rear strap button and hung the first thing I could find
that would do the job - a large ish tin of paint.
That just about balanced it, a treat!
Weight of the paint tin - just over 2 1/4 lbs!!
So, a total of 12.25 lbs!
Mmm, makes a Forty sound quite reasonable.
Waits for deluge of abuse! :mrgreen:
Cheers. :)
Now a little more wiser. . . . .
« Reply #31 on: June 12, 2013, 11:58:16 AM »
The T-40 is shaped like a P bass. It would balance perfectly on a strap even if it weighed 9 lbs. Anything over that is unnecessary weight and does not improve the balance.
« Reply #32 on: June 12, 2013, 06:09:08 PM »
When Mark F. (fur85) owned the Epi Embassy now owned again by gweimer, he added a weighted bag to the lower strap button to make it balance. That looked odd enough, but a large can of paint sounds unwieldy! Whatever works, I suppose.
When Tommy Stinson was in the Replacements, he had a lead weight inset into the lower treble side bout of his Thunderbird to make it balance.
« Reply #33 on: June 14, 2013, 03:13:30 AM »
Paul McCartney attaches his wireless transmitter and battery pack to the strap near the lower strap button to balance his >5lbs. Höfner.
