Author Topic: 2013 ExplorerBird...there's gold on them thar basses.  (Read 15167 times)
Re: 2013 ExplorerBird...there's gold on them thar basses.
« Reply #30 on: January 13, 2013, 02:38:29 PM »
Art, personified... 8)
« Reply #31 on: January 13, 2013, 07:58:01 PM »
Thanks Carlo, nice tutorial!
« Reply #32 on: January 15, 2013, 04:14:09 PM »
And I'm the oddist.
You're welcome Bill!
Did most of the major sanding and shot a coat of sealer yesterday.  Today was another 79 degree one, perfect for opening the doors in the shop and getting some stuff done!  First up was lacquer puttying spots that needed to be filled, you can see one by the control cavity and a few pink spots on the side that have already been sanded.  I used my usual pendaflex folder to do a p/g template.  First trace the body outline where needed.
Extend the horn lines to make a triangle.  Cut with exacto and check for accuracy.
Place the triangle in proper position and draw line for trimming.
Lacquer putty work done, everything sanded to 240 and second sealer coat applied.
P/G template finished
Body filled with drywall mud, sanded to 240/320 and 2 coats of white primer.
If I was doing Pete's I'd almost be finished.  Tomorrow, sand with 320/400, shoot one more primer coat, one color coat and 2 clear coats.
« Reply #33 on: January 17, 2013, 11:28:12 AM »
No trees!  Not done until they show leaves.
« Reply #34 on: January 17, 2013, 12:43:11 PM »
Four tree's a jolly wood fellow... :mrgreen:
« Reply #35 on: January 25, 2013, 04:20:27 AM »
One word: GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAASSSSSSS
« Reply #36 on: January 25, 2013, 05:37:30 AM »
Color coat done
Clear coats on.  Buffing and assembly begin Monday.
« Reply #37 on: January 26, 2013, 09:39:56 AM »
Aaauuuuugh.
Surely there's a squirrel somewhere needing your attention.....   :P
« Reply #38 on: January 26, 2013, 02:35:34 PM »
You nailed that color - love it!
« Reply #39 on: January 27, 2013, 01:29:52 PM »
Carlo's supper...?
« Reply #40 on: January 27, 2013, 02:21:43 PM »
Carlo's supper...?
I wish...my Cajun  mother in law used to make delicious squirrel gumbo and squirrels in gravy.
« Reply #41 on: January 27, 2013, 03:08:48 PM »
Lets face it - everything is better with gravy ;D
« Reply #42 on: January 27, 2013, 03:36:53 PM »
My avatar's been pickling in (non-veggie) Guinness for years now...
Jackie's uncle used to describe 'coon as "gud eet-in"... not much objection to road-kill neither... with or without the gravy... sometimes comes with it's own stuffing...  ;D
« Reply #43 on: January 29, 2013, 11:41:55 AM »
Today's the big day; color sand, buff and assemble.  Wet or dry paper, micromesh abrasive cloth, rubber blocks and dish detergent.
First, 600 grit wet or dry paper to level the paint, dish soap in the water for lubrication.
Micromesh cushioned abrasive, from 1500 to 12000 grit.  Going through these takes less than 5 minutes per grit.  It's flexible glued to fabric backing,  I've been using this set for over a year, it just does not wear out.  after the 12000 grit buffing with Meguiar's Ultimate compound takes around 10 minutes per side.  About 1 1/2 hour for the whole color sand/buff operation.
Here's my soldering setup.  Piece of MDF with holes to stick pots and jack in, less than $20 soldering station that kicks butt.
Assembly took another hour.  Tomorrow pick guard gets done.
« Reply #44 on: January 29, 2013, 01:56:28 PM »
WOW!
There's the trees  ;D
« Last Edit: January 31, 2013, 01:24:54 PM by Rob »
