Author Topic: Ampeg B25  (Read 3634 times)
SKATE RAT
Ampeg B25
« on: July 22, 2009, 08:47:26 AM »
does anyone know anything about these?i cant really find much info.
Re: Ampeg B25
« Reply #1 on: July 22, 2009, 08:58:04 AM »
Not much. It was a 50 watt tube head, and I think came with a 16 ohm cab. You can probably find a schematic online somewhere, just check and see what the output transformer is tapped for.
It wouldn't be suitable for a loud gig.
SKATE RAT
Re: Ampeg B25
« Reply #2 on: July 22, 2009, 09:07:51 AM »
i have a B25 and a Plush royal bass tube head (not sure of wattage,uses 4 6L6's) i also have an empty 2X15 cab.i'm curious about runnin' both heads.is it possible? how? why? i'd like more power/volume/balls.is this a good idea.not sure what speakers to get. or i was also thinking to use the 2X15 with the plush and get a 4X12 for the Ampeg B25. would this be louder? do more speakers equal more volume?
Re: Ampeg B25
« Reply #3 on: July 22, 2009, 09:42:07 AM »
The best way to get more volume is more speakers. But find a schematic for the B25, see if it's set up for 16 ohms, you want to be careful with that.
Send a PM to bobyoung if he hasn't responded here within a couple of days, he can probably answer your questions.
Re: Ampeg B25
« Reply #4 on: July 23, 2009, 04:23:41 AM »
 I rehearse with one of these, great sounding little amp !
Re: Ampeg B25
« Reply #5 on: July 23, 2009, 05:15:48 AM »
I use a Whirlwind A/B box when I run two heads. Two inputs one output to the bass works great, old school Bi amp.
« Last Edit: July 23, 2009, 08:59:20 AM by godofthunder »
Re: Ampeg B25
« Reply #6 on: July 23, 2009, 08:59:53 AM »
I have a original 2x15 cab it is 16 ohms.
Re: Ampeg B25
« Reply #7 on: July 23, 2009, 11:55:27 AM »
Does the head have taps for 8 and 4 ohms? That would affect what he might be able to run. I haven't seen one in so long.
SKATE RAT
Re: Ampeg B25
« Reply #8 on: July 23, 2009, 06:29:41 PM »
ok,i've never used the head. i got it with no tubes. so i'm gonna take both this and my plush to get re-tubed etc.(hopefully i'll get a better deal)but it has been modded there are 2 extra jacks.not sure how its wired.since the 2X15 cab i have has no speakers i could just restore it to stock.and get the correct speakers.the whole ohm thing confuses me ???i read that the B25 can run 1 2X15 cab at 16ohm or 2 cabs at 8ohms. does this mean each speaker is 32 ohm? i know the 10" s in my SVT are 16 ohm  not sure about the 15" can some one please explain the ohmage thing and how it pertains to wattage and volume.  from what i can tell about B-25's people say they sound great and are pretty loud and mine is an early one from N.J.
« Last Edit: July 23, 2009, 07:25:27 PM by SKATE RAT »
Re: Ampeg B25
« Reply #9 on: July 23, 2009, 10:03:47 PM »
It's a tube amp, the watts will be the same regardless of whether it's 16 or 8 ohms. More speakers will increase the volume.
Edit: (and a Disclaimer: I'm not an amp guy)
From a schematic I found online, it looks like a 16 ohm plus an out for an extension cab which would need to be 16 ohm, making an 8 ohm load overall if you're running a second cab. But it also looks like it can probably be easily modified by a qualified amp tech to run 8 ohm cabinets.
« Last Edit: July 23, 2009, 10:23:27 PM by Dave W »
SKATE RAT
Re: Ampeg B25
« Reply #10 on: July 24, 2009, 04:44:04 AM »
what would be the benefit of running an 8 ohm cab?
Re: Ampeg B25
« Reply #11 on: July 24, 2009, 04:47:35 AM »
I'll have to check on Monday, the amp is at the rehearsal studio. The cab is 16 ohm so I would guess the 2 15's are  8 ohm in series.
Re: Ampeg B25
« Reply #12 on: July 24, 2009, 07:53:16 AM »
That's what it looked like from this schematic: http://www.drtube.com/schematics/ampeg/b25-jp.gif
Re: Ampeg B25
« Reply #13 on: July 24, 2009, 07:56:47 AM »
No particular benefit with a tube head, it's just that today you don't see many 16 ohm cabs.
