Gear Discussion Forums > Rickenbacker Basses
4001 pickup question
ilan:
A 1979 4001's neck was designed for light-gauge strings, .040-.100 set. Some 4001's can handle slightly heavier gauges, but others will suffer neck damage, warp etc.
Also, it's important to understand the truss rods. Pre-85 Rics have folded expansion rods, which operate differently from compression rods in post-85 Rics or any Fender, Gibson etc. Set-up is different, and many luthiers don't know how to properly adjust those necks. Attempts to adjust the rods like you would in a Fender, for example, can result in popping the fretboard or cracking the neck.
In short, to adjust the "old style" rods, keep string tension (bass tuned to pitch - don't detune you bass even for long storage), then loosen the nuts a bit, pull the neck backwards manually to where you want it to be, and then "lock" it into place with the rods.
In other words, with a "standard" (Fender style, actually any make other than Ric) truss rod you turn the nut to move the neck, and with the folded type expansion rods you move the neck manually and use the rods to "freeze" it in that position.
Once you understand the expansion rods and how to adjust them, you'll be able to do your own setups.
Like Dave wrote, Joey's website is excellent read.
Also, this guide written by Ted Staberow and posted to the RRF is a must-read IMHO for any pre-'85 Ric owner.
Now let's see some pics! :thumbsup:
Navigation
[0] Message Index
[*] Previous page
Go to full version
