Gear Discussion Forums => Bill's Shop: Projects, Mods & Repairs => Topic started by: SKATE RAT on September 14, 2016, 03:28:49 PM
Title: I'm Slipping
Post by: SKATE RAT on September 14, 2016, 03:28:49 PM
What is the best way to keep down slipping bridge studs? Glue?
Title: Re: I'm Slipping
Post by: Pilgrim on September 14, 2016, 04:56:42 PM
What is a bridge stud?  Do you mean the set screws in a Fender-style bridge?  if so, clear nail polish works fine.
Post by: FrankieTbird on September 14, 2016, 06:09:04 PM
Yes, a little glue should do it.  Make sure you don't damage the ground wire.  Or you can add a separate tailpiece.
Post by: chromium on September 14, 2016, 07:47:43 PM
For bridge studs that have a tendency to lift out of the body (as on some of the 3-points) I usually just pull them out all the way, drip some CA/superglue down the edges of the holes, let it dry, and then press the studs back in snug.
Post by: SKATE RAT on September 15, 2016, 04:34:06 AM
Thanx, I figured that would be the best way but wanted to ask anyway
Post by: SKATE RAT on September 15, 2016, 04:35:33 AM
the big ol' bolts on 3 point bridges
Post by: Alanko on September 15, 2016, 04:36:38 AM
I did something like this on my Aria bass, as per my thread on here. I didn't glue the insert that had the ground wire running to it, and used 2-part epoxy on the other three.
Post by: Pilgrim on September 15, 2016, 12:46:55 PM
OH!  I picked that up from a post following your original, but I had no clue. Thanks.
I do the same as Chromium - pull the stud mount out, paint the inside of the hole with super glue, re-insert the stud in place and tap gently with a rubber hammer to seat it fully.
Post by: FrankieTbird on September 15, 2016, 12:55:12 PM
Doesn't the Ripper allow for strings thru the body? That would surely put an end to bridge posts pulling up.
Post by: SKATE RAT on September 15, 2016, 03:24:42 PM
Yes, but then the thread on the strings is past the nut. And I love boomers
Post by: FrankieTbird on September 15, 2016, 06:33:41 PM
That sucks.
Post by: Dave W on September 15, 2016, 07:08:33 PM
Boomers do come in extra long scale.
Post by: SKATE RAT on September 16, 2016, 07:11:29 PM
Do they? I've not seen them. I'll look into that
Post by: Dave W on September 16, 2016, 08:54:03 PM
They do (http://www.ghsstrings.com/products/13270-extra-long-scale-bass-boomers?category_id=1964722-bass-boomers). You can tell by the X following the sku number, i.e. M3045X for the 45-105 set instead of just M3045, and the package says "Long Scale +". Guitar Centers in this area stock them or you can order from MF. They should cost about a buck more than the regular set.
Post by: SKATE RAT on September 20, 2016, 02:24:56 PM
Thanks, I'm gonna pick up some of those
