Gear Discussion Forums => Other Bass Brands => Topic started by: Johnbob on July 18, 2011, 12:31:46 AM
I think the Bachbird is 51" (I don't have mine on me so I can't check for sure) and I found this case on Ebay, http://cgi.ebay.com/New-Epiphone-Case-Epiphone-ThunderBird-Bass-/160590678713?pt=Guitar&hash=item2563f34ab9#ht_576wt_1056 and I was wondering if it will fit. It says that the case length is 51" but I'm not sure if that is the interior or exterior length. It says
The Thunderbird Hardshell Case #39
. Is this some sort of model number maybe? Does anyone know for sure it the Bachbird will fit in it? Thanks.
I have the same case for my BaCHbird. But I did have to take out the shaped interior and turn it around and reshape it a little but.
Now it's a snug fit.
The case is kinda heavy.
(http://www.superfloor.net/emptycase.jpg)
(http://www.superfloor.net/BaCHbird-in-case.jpg)
(http://www.superfloor.net/BaCHbird-in-case2.jpg)
Cool, I just ordered the same case online. I got a good deal on it too, it was used for $38.99 plus $9.99 for shipping. Let's hope it fits and the seller knows what they are talking about when they described it.
I think there are different size Epi T-bird cases. I have both a fitted case and a generic case and my BaCH would fit in neither. The case I ended up using was, I suspect, an Explorer case. It's HUGE! Because of the angle of the headstock the depth of the case made for a really snug fit as the bass had to angle slightly upwards from the body to the headstock. It's tight but it's not moving around!
Yeah, I know there are multiple different Epi Thunderbird cases out there. I always ask about the dimensions when they pop up on Ebay and most of them seem to be 48 inches. I've heard that they make a longer one too that was 51 inches so I'm assuming this is it. At least I hope it is. I can't imagine they make three different sizes but with my luck they probably do. We'll find out soon enough though.
You are right about most of them being around 48 inches long, which is WAY too short. You are wise to ask the length on them!
Since the BaCHs come in at 51.5" they are about the longest basses other than the Scroll basses. The unfitted case I have is also a lot wider than a T-bird case so I assumed it was for an Explorer.
Keep us posted!
As an FYI, here are some comparison pics.
http://bassoutpost.com/index.php?topic=3128.0
I have a 51" Exterior Dimension Epi TBird case. It had an Epi bolt on Bird in it when I got it. This is the same model EKL case that Denis sent me his Fenderbird in. Bachs won't fit in it, they're about 1 1/2 inch too long. Orville by Gibson Reverse fits very tightly but '60 Reverse fits easily.
I have an original 70s Thunderbird RI case, fits ALL TBirds but you'd have to rearrange the foam for an NR. Ditto the current Gibson case for the USA Thunderbird.
That was a different case, if I remember correctly. The one I sent the Fenderbird in was an unfitted Ep-T-bird case. The Fenderbird fit in it because it's shorter than a T-bird, mostly because of the shorter headstock.
For comparison, see the pic below.
Left to right: Epi T-bird case, Victory case, '74 P-bass case, G&L molded case, Epi case for the NR, two Ripper cases. It's 4 inches longer than any of the other ones. I believe it was intended as an Explorer bass case. The body cavity was square and even the NR slid around a bit, with several inches of open space on all sides.
(http://i94.photobucket.com/albums/l111/bigtreebluesea/BaCHbird%20NR%20case/DSC05901a.jpg)
God damn it, I already bought it. Great, now I'm going to have send it back or resell it. F*&k!!!
On another note: Whoa, yeah, that Explorer case is HUGE!!!
Wait until it shows up because you never know. One guy shipped me a T-bird case, BUT it was actually a Firebird case and stupid me never thought to ask for the dimension beforehand...
When I tried, my Bachbird was actually longer than my entire Epi case, inside and out. Epi case sure fits my JAEbird snugly though...
Oh, on another, related note, the Japanese Epi T-bird case (and Orville cases I assume) are different still: deeper with different formed shape.
My '89 Orville only came with an OEM gig bag. The Epi case I have isn't completely form fitting, just around the lower horn. Its 5" deep.
Hmm, interesting. The formed Epi case for the Korean T-bird I have is fully formed. Maybe they kept trying to get it right! The Jap Epi case is fully formed as well. It's a really nice case too. This reminds me that I haven't messed with the T-bird in a while...
Just wait till you got it. Remember; mine fits!
Yes, there is hope.
Yes, it fits!!! At first it looked like it wasn't going to but then I realized that once I pulled the styrofoam out I would be able to push the styrofoam closer to the edge a bit. If that makes sense? I ripped it all out, flipped it over and reshaped it a bit so it would now fit an NR bird. Basically, I did the same thing as you Rob. Now it fits perfectly. I've been looking for a case for over a year and every time I would find one it would happen to be when I had no money and they were always kind of expensive. The lowest I was finding was $89.99 but the shipping was always around $29.99. I got the deal of century on this one, it was $39.99 and the shipping was only $9.99. It said it was an open box item so I assumed it would be scuffed up a bit but it was brand new and still in the original shipping box. I'm so stoked I got such a great deal.
Very cool! Now I wonder why my case didn't work...
There are 2 different ones by Epiphone (that I know of). One's interior length is 48 inches long and the other is 51 inches long. I guess mine is referred to case #39. I'm assuming that is some sort of model number because every time I see one that is 51 inches the product details for it will say Epiphone Thunderbird case 39. But mine barely fits. I had to make it fit, not just shape wise but length wise. But obviously the 48 inch case won't fit no matter what you do to it.
I've got that same case as the one shown in post #2. I keep my Greco reverse TB II in it. Nice case, fits like a glove, and waaaay cheaper than a Gibson case.
