Author Topic: Incoming! Ampeg V4BH  (Read 11865 times)
Re: Incoming! Ampeg V4BH
« Reply #30 on: May 24, 2010, 09:12:26 AM »
If you start pushing much over 200 watts through them they're going to start blowing. I blew the the top speaker in my old Ampeg more times than I can even remember.
Me too! I finally got tired of re-coning the JBL D140s and switched to EVM15Ls. LOVE those speakers!
« Reply #31 on: May 24, 2010, 03:58:46 PM »
Actually most 2x15's from the 70's, and especially the V4B 2x15, would probably kill most modern 10" cabs in terms of efficiency. Where modern speakers win out is in power handling and excursion, since they are designed to be installed in ported cabinets from the ground up. There's a lot of fuss made over efficiency specs, which, like 'peak power handling,' is generally a spec so finely made, it's damn near a lie. What a cab does at 1kHz, where the spec is most often measured, is as Dave says, meaningless to bass players.
Look, I'm sure your are correct, I'm not going to argue.
I'm just trying to understand why people are saying that 100 tube watts is not loud enough.  My experience with this head is the opposite.  I have plenty up my sleeve playing through a pair of 2x10 cabs with a 7 piece band (including 2 guitars, keys, sax), with the guitarist right next to me playing a cranked Super Twin (180w).  It's all good :-)
« Reply #32 on: May 24, 2010, 07:29:24 PM »
Mark, I can't argue about what works for you. I just know what didn't work for me.
If 100 watt tube heads worked for everyone, the SVT wouldn't be iconic.
