Author Topic: Rick-O-Sound question  (Read 1837 times)
« on: November 18, 2010, 09:53:56 AM »
Anyone have a source for a box for the Ric-O-Sound configuration? Seems like a link to a source was posted a while back but I couldn't find it.
Re: Rick-O-Sound question
« Reply #1 on: November 18, 2010, 10:37:06 AM »
« Reply #2 on: November 18, 2010, 11:45:34 AM »
hieronymous
« Reply #3 on: November 18, 2010, 12:24:53 PM »
« Reply #4 on: November 18, 2010, 12:27:26 PM »
If you solder and are inclined to make one, its a pretty simple build.  I needed some channel insert cables for a mixer, so I made some without a box-
One end has a 1/4" TRS (tip/ring/sleeve; aka "stereo") plug, and there are two cable whips coming out of this that terminate with 1/4" TS (tip/sleeve; aka "mono") plugs.  The tip of the stereo plug goes to the tip of one of the mono plugs, ring of the stereo plug goes to tip of the other mono plug.  Connect all plugs' sleeves together (ground), and voila.  You could of course build it in a breakout box with jacks, etc... like the Ric units.
There's a diagram somewhere in the mixer's manual which I can find/post it if it helps anyone.  That cable config works with my 4001 and former Mangum-1.
« Reply #5 on: November 19, 2010, 06:20:53 AM »
Also http://www.bayoucables.com/bayouosound-box-p-222.html
Much cheaper and without international shipping!
Me? Make something electrical? Heh If it's more complicated than soldering I get antsy thinking I'm going to electrocute someone or knock out a power grid...
