Author Topic: A flats vs rounds comparison  (Read 3430 times)
  • Low Impedance LP's
Re: A flats vs rounds comparison
« Reply #15 on: June 01, 2020, 01:19:34 PM »
The Memphis ES Les Paul Bass came from the factory with flat wounds. The only new bass I’ve bought that was shipped with them.
« Reply #16 on: June 01, 2020, 11:08:04 PM »
My Vox Spyder came with tapewounds. It was made in '68 and I bought it new in '69. It was an Eko-made bass and Eko sold strings under their own name so I'd guess that was the brand. I never changed them the whole time I owned the bass.
« Reply #17 on: June 02, 2020, 07:11:16 AM »
I’m not sure if the Tape Wounds are any good anymore, but here is a batch of never used Gibson bass strings. (1) Tape Wound, (1) Flat Wound & (1) Round Wound.....
« Reply #18 on: June 02, 2020, 09:48:18 PM »
Good price for 1998! Why wouldn't the tapewounds be good? The nylon wrap shouldn't deteriorate.
« Reply #19 on: June 03, 2020, 07:22:30 AM »
They must have sat in the store for 25 years. I offered them $10 a pack & they were happy to let them go..... They also had NOS Ripper/Grabber cases in stock at the time.
Nylon coating still looks as new!
« Last Edit: June 03, 2020, 09:40:04 AM by Grog »
« Reply #20 on: June 03, 2020, 11:03:26 PM »
As I suspected!
I'm surprised Groth had anything around that long. Old stock was the province of Torp's in St.Paul and Suneson's on E. Lake Street.
« Reply #21 on: June 04, 2020, 10:34:29 PM »
Tapewounds often necessitate widening the nut slots, something I don't want to perform on a vintage bass.
« Reply #22 on: June 05, 2020, 09:58:40 PM »
I've never had to widen a nut slot for tapewounds, the nylon wrap has compressed enough without binding in the slot.
« Reply #23 on: June 08, 2020, 12:48:47 PM »
D'addario's and GHS are normal gauges
« Reply #24 on: June 08, 2020, 05:33:30 PM »
The NOS Gibson strings seem to be extra light gauge. .091 E string......
« Reply #25 on: June 08, 2020, 08:39:05 PM »
You mentioned that these were years old when you bought them. Back in the 70s, they were probably the only flatwound set Gibson offered.
Bubbalou88
« Reply #26 on: July 06, 2020, 04:40:23 AM »
I have been very happy with TI Jazz Flats and LaBella Low Tension Flats (little more tension than TI's but less than most others)
CEO of Retired
Bubbalou88
« Reply #27 on: July 08, 2020, 03:54:47 AM »
For the most part I use TI Jazz Flats or LaBella Low tension flats( little higher tension than the TI’s)
For rounds I like DR Silver Stars or Black Beauties ( both are thin coated) for less Finger to string noise . If you use a coated string I recommend top loading only as the feed thru the body string ferrules are not typically grounded and might pick up noise
« Last Edit: July 08, 2020, 04:16:02 AM by Bubbalou88 »
CEO of Retired
tore00
  • Southern by grace of God
    • Snakebite
« Reply #28 on: July 08, 2020, 08:44:06 AM »
I've a 1967 Guild Starfire and I stringed initially with Thomastick flats. No sustain, maybe because of the high magnetic field of the bisonic pickup. I tried to lower the poles, but no luck. I changed to roundwound and she plays beautiful. Deep, resonant, a great bass. I presented her in this post
http://bassoutpost.com/index.php?topic=10154.15
Bubbalou88
« Reply #29 on: July 14, 2020, 01:14:01 AM »
Yep, it is amazing how a string works well on one bass or guitar and not another mostly due to pickup characteristics!
CEO of Retired
