Author Topic: CURRENT CATALDO  (Read 138148 times)
Re: CURRENT CATALDO
« Reply #750 on: April 28, 2019, 06:25:08 AM »
Art, my Don... nuf said... :mrgreen:
Re: CURRENT CATALDO
« Reply #751 on: April 28, 2019, 11:30:17 AM »
Well, around here we call it Blart, but thanks, Ken!
I'm sending a PM concerning tech stuff regarding photography.
« Last Edit: April 28, 2019, 11:41:14 AM by dadagoboi »
Re: CURRENT CATALDO
« Reply #752 on: May 03, 2019, 05:17:47 AM »
Uli Salm, my patron. six Cataldos among his five hundred plus bass collection.
40th anniversary celebration of 'Rudolf Rock & die Shocker' in Hamburg with two Cataldos, one on the shoulder and one in the rack.
Re: CURRENT CATALDO
« Reply #753 on: May 03, 2019, 06:42:16 AM »
That's great Carlo!
Re: CURRENT CATALDO
« Reply #754 on: May 03, 2019, 05:12:17 PM »
Five... HUNDRED???
Re: CURRENT CATALDO
« Reply #755 on: May 04, 2019, 08:49:17 AM »
That's great Carlo!
Thanks, Rob
Five... HUNDRED???
He auctioned off about 150 two years ago on Heritage including a dozen or so '60s Reverses. I'm sure he kept the best ones. Before I built this we had a good back and forth as to what to do including pix of a bunch of his 55-56 P's.
Ended up doing a little more relicing than this pic but less than originally planned.
Re: CURRENT CATALDO
« Reply #756 on: May 20, 2019, 06:11:21 PM »
I'm finally moving on from shimmed neck pockets. Made a quick jig that rises .030 from the 15th fret to the 20th which gives about a .125 rise at the bridge on a 34" scale neck.
I worked with the blank of a 32" scale G8r I'm building and then decided to upgrade my MAX41 to a 21 fret set neck with tilt headstock and ebony fretboard.  Also going to do a raised center on it.
Harbor Freight $10 Wheel of Death makes a quick job of contouring.
One piece 1-1/2" poplar blank weighs 3.8 lbs.  About the same as basswood but harder.
Saturday Shop Snap
Re: CURRENT CATALDO
« Reply #757 on: May 21, 2019, 12:49:24 PM »
 8) 8) 8)
Re: CURRENT CATALDO
« Reply #758 on: May 22, 2019, 02:57:57 PM »
They just keep improving Carlo.
Re: CURRENT CATALDO
« Reply #759 on: June 02, 2019, 09:42:25 AM »
I custom mixed this from GM9792 waterbase/solvent basecoat with Kolorefx  'Silver Stunner' flake topped with Hi Performance Clear Acrylic Lacquer.  It's a combo of modern basecoat/clearcoat without the Isocyanate high or pot life of Urethane. It's actually 3 stage: Flat black/ Base Coat/Clear Coats.  The color coat required about five ounces of material.
It looks a lot better in this video:
Gets color sanded and buffed in about a week. The automotive acrylic lacquer is a durable but thin finish(compared to urethanes) with great transparency.  I'm gonna add 2 drops Mohawk Pano Lacquer per gallon and call it 'Nitro' :) Pretty much what everybody else does...
Re: CURRENT CATALDO
« Reply #760 on: June 02, 2019, 10:04:33 AM »
Re: CURRENT CATALDO
« Reply #761 on: June 02, 2019, 01:43:43 PM »
That came out great.
Re: CURRENT CATALDO
« Reply #762 on: June 02, 2019, 02:50:26 PM »
Thanks, guys! Difficult painting last week with temps over 100 and humidity high. Heat index of 112 Tuesday.
Re: CURRENT CATALDO
« Reply #763 on: June 03, 2019, 08:05:59 AM »
That is one of the coolest finishes I've seen.  Fabulous!
Re: CURRENT CATALDO
« Reply #764 on: June 04, 2019, 02:38:55 PM »
Lots of  8)
