Author Topic: Three point bridge question  (Read 2147 times)
Re: Three point bridge question
« Reply #15 on: January 09, 2023, 04:33:46 PM »
They also come in 1/4 or 45 degree off-sets...
Epi 3 point bridges may be a bit smaller... I swapped a black Epi one (esthetic reasons) for the one off my RD (with Scott) and had to replace all the posts and re-position them...
« Reply #16 on: January 09, 2023, 07:43:45 PM »
It's a gynaecological screwdriver, available from certain medical hardware suppliers.
How did you know? They are available as sets too. At well-stocked David Cronenberg outlets ...
« Last Edit: January 09, 2023, 07:50:49 PM by uwe »
« Reply #17 on: January 09, 2023, 11:14:59 PM »
Yep, offset screwdriver. Available at home improvement stores, auto parts stores, and of course Amazon.
« Reply #18 on: January 10, 2023, 12:23:35 AM »
Now tell me Uwe, how does it help with the string being in the way with the three point bridge?  :popcorn:
« Last Edit: January 10, 2023, 04:28:34 AM by Basvarken »
« Reply #19 on: January 10, 2023, 02:44:15 AM »
I never had a problem. Just use a skinny precision screwdriver.
Examples:
If it is long you can still get a good grip from the side of the string due to the small angle:
« Reply #20 on: January 10, 2023, 05:33:36 AM »
Actually, it does but you have to of course reposition it once the string gets in the way. If you're too lazy for that (and I somehow assume you are, Hollän Niederländer!), I reccommend a ratchet offset screwdriver!
Not that I would need one, I get along fine with a regular screwdriver as long as it is long enough, but I prefer a stronger, yet narrow tip to not strip the screw.
« Reply #21 on: January 10, 2023, 06:35:05 AM »
Exactly. And you don't have to reposition it.
So why bother with that silly one you found in a gig bag decades ago?
« Reply #22 on: January 10, 2023, 07:43:40 AM »
But all I innocently wanted was to give some unselfish developmental aid to our Amerikaans vriendjes! We have a great tradition of helping them surmount technical obstacles. It's not rocket science.
« Reply #23 on: January 10, 2023, 09:37:48 AM »
 All I have to do is take it to Lull's, then I don't seem to have to goof with it forever after.  8)
« Reply #24 on: January 10, 2023, 12:42:39 PM »
I would take it to Lull's, too, if I wasn't 2,500 miles away.  I envy you having a place like that to go to.
« Reply #25 on: January 12, 2023, 07:10:21 AM »
Interestingly, the 3 point bridge provides one example of where putting lube on your driver to do some screwing in a tight spot doesn't make the whole ordeal any less of a pain in the ass.  :rimshot:
« Reply #26 on: January 12, 2023, 09:12:19 AM »
To the contrary, I think it is a deplorable sign of our valueless, even heathenish times that young, impressionable people take a look at a three pointer today and immediately ask "Now where do I start screwing what why?" rather than letting a firm set of beliefs guide them to the straight and narrow.
« Reply #27 on: January 14, 2023, 10:26:47 AM »
I've had one of those offset tip screwdrivers in my tool box for 40+ years....really.
Same!
Since we're on the subject - where can I get one of those bars that extend the string length behind a 3 point? I'd like to put one on my Rumblekat.
« Reply #28 on: January 16, 2023, 06:28:00 AM »
I can look in my parts box. The thinner or the thicker one? Does size matter to you?
« Last Edit: January 16, 2023, 06:44:20 AM by uwe »
« Reply #29 on: January 16, 2023, 12:22:29 PM »
I did not know there were different sizes? I'd probably go thinner since it's my first time using one.  ;D
