Author Topic: EB Banjo Tuners - Replacements / Replica Tuners  (Read 4284 times)
dc10bass
« on: December 01, 2014, 07:49:01 AM »
Hello Group...
Is there currently anyone producing replacement / replica EB Banjo Tuners?
I see that Steinberger makes something similar for guitar, but doesn't appear they do for bass?
I work doing CAD for the Automotive industry and was considering designing and machining a few sets.
Is there maybe another alternative that has been successfully used in place of the original Banjo Tuners?
[Info from www.flyguitars.com]
EB Banjo Tuners
Gibson part number MH-570-P (1965).
Sealfast 12 to 1 ratio, as used on 1950s EB/EB1, and EB2 basses and the melody maker style slap body EB0
Curt
www.talesofcream.com - A Tribute to the Music of Cream
www.facebook.com/LIVETHEWHO - The Who Tribute
Re: EB Banjo Tuners - Replacements / Replica Tuners
« Reply #1 on: December 01, 2014, 08:40:51 AM »
I remember seeing something at Stew Mac a year or 2 ago - try perusing their website.
dc10bass
« Reply #2 on: December 01, 2014, 08:49:48 AM »
Yes, those are the Steinberger Tuners for guitar / replacement for Gibson Firebirds.
...Does not look like it could handle bass strings.
http://www.stewmac.com/Hardware_and_Parts/Tuning_Machines/Guitar_and_Solid_Peghead/Steinberger_Gearless_Tuners.html
« Reply #3 on: December 01, 2014, 08:50:34 AM »
Neither could the originals.  They litterally were banjo tuners (same as era Firebirds).
Worst case you can bore out the string holes a bit.
« Reply #4 on: December 01, 2014, 10:48:36 AM »
I don't think there are enough basses around to make it a worthwhile project
I bought my '60 EBO in '65 for $40.  The first thing I did was shell out another $40 for a set of Schallers, a lot of money at that time for a 19 year old.  That's how bad the banjos were.  I saved them for a long time but they eventually disappeared.  If they hadn't I would have put them back when I did the last refurb.
But I have no interest in aftermarket banjos.  They wouldn't work as well as the Hipshots I'm using now and they wouldn't be OEM.  So I don't see the point.
Dead on replicas might have an appeal to others, though.
« Reply #5 on: December 01, 2014, 12:33:56 PM »
Real banjo tuners have a 4:1 ratio.
Not very practical for bass.
« Reply #6 on: December 01, 2014, 01:00:13 PM »
The Steinbergers are 40:1.
.... but they don't look anywhere close to 'right.'
« Reply #7 on: December 01, 2014, 01:20:12 PM »
The 4:1 ratio is for quick changing to different tunings during a show, NOT for accuracy.
dc10bass
« Reply #8 on: December 01, 2014, 01:36:28 PM »
So how bad is a tuner with a gear ratio of 14:1?
« Reply #9 on: December 01, 2014, 04:48:57 PM »
Never have paid much attention to my bass tuners and tuning ratios...as long as they tune.
Surprises me that the Gibson peg gives a 12:1 ratio, because I thought the 4:1 in banjos was a result of the "planetary" design's shortcomings.
« Last Edit: December 01, 2014, 06:22:58 PM by patman »
mc2NY
« Reply #11 on: December 02, 2014, 07:10:59 PM »
I think if you made a set for Bass, with larger string holes, it would be useful.
But, if you want to recoup your costs by selling more, I would also make guitar sets with a ratio up near the Steinberger tuners. The Steinbergers are good but you need to mod you guitar to use them.
A set that fits exactly to the original holes but has a higher ratio would be a great option.
« Last Edit: December 09, 2014, 03:54:23 PM by mc2NY »
dc10bass
« Reply #12 on: December 03, 2014, 07:42:11 AM »
But, if you want to recoup your costs by selling more, I would also make guitar sets with a ration up near the Steinberger tuners. The Steinbergers are good but you need to mod you guitar to use them.
A set that fits exactly to the original holes but has a higher ration would be a great option.
Nice one, Thanks!
mc2NY
« Reply #13 on: December 09, 2014, 03:57:35 PM »
Oh.....and interchangeable plastic or metal buttons, so the buyer can choose either.
I can see some guys wanting metal buttons even on an EB, in some cases or maybe someone wanting to try plastic ones on an old Firebird.
« Reply #14 on: December 16, 2014, 07:47:28 AM »
Late to the party. Ibanez did make a copy for their 70's Firebird copies. Pretty much same damned things as the original Gibsons. They were a Kluson thing and the only difference between the guitar and bass was the shaft which had a bigger hole for a bass string and a slightly different size.  The thing that sucked out loud was the offset design. The tension of a bass string tuned to pitch would physically pull the shaft gear away from the gear on the tuning button. The thing would slip like crazy, not to mention that it was a bear to turn if it kept contact. The only way to get them to work was to use short scale strings with the lowest tension possible. Considering the original headstocks were smaller to boot, installing bass tuners left very limited options. There were the Schallers later on, but back in the day most good bass tuners wouldn't fit without hanging over, and reaming the headstock out wasn't the wisest thing to do to their weakest spot. Those crummy Japanese things fit ok but looked awful. Through extensive trial and error in the days before Internet and buying parts via mailers from City Lights, I found that Grover Imperials fit the Gibson head stocks without Reaming, and worked ok with the shaft hole opened up a tad. Aesthetics are subjective but I thought they looked less appalling than Schallers or clover leaf keys. I wish they had Steinberger things back then. But then again, a set of bass tuners cost close to what anyone paid for a 50's Gibson bass back then.
