Gear Discussion Forums => Other Bass Brands => Topic started by: ilan on June 25, 2023, 01:58:38 PM
https://www.ebay.com/itm/166190937638
What do you think... if it stays cheap it could be a fun bass, right?
(https://i.ebayimg.com/images/g/8PwAAOSwYBVklwLW/s-l1600.png)
A "defect" right were the s/n probably was? I'd pass.
Could be a bargain, though.
Could be fun. But don't expect it to be anything like the real lo-z Gibson Les Paul Bass.
Pickups are not lo-z. And most likely not even humbuckers.
I owned a similar one. The neck was a multiplex laminate and the fretboard had developed a huge bump near the neck joint.
Body was semi-hollow. Pickups were microphonic.
A cute little bass, but it always was a stepchild in the family.
I wonder what the second jack is for on the front by the volume knob………..
Neck needs a reset by the way...
https://www.ebay.com/itm/334922736780
Another one. EUR400
(https://i.ebayimg.com/images/g/cyoAAOSwaI9kecKx/s-l1600.jpg)
I owned one exactly like that one. With shortcomings as described above.
Except mine had the CBS logo silkscreened on it instead of the Master M
https://www.enkoo.nl/cbslespaulbassjapan.html
(https://www.enkoo.nl/uploads/1/3/3/7/13376708/img-3972_1_orig.jpg)
(https://www.enkoo.nl/uploads/1/3/3/7/13376708/img-3967_1_orig.jpg)
(https://www.enkoo.nl/uploads/1/3/3/7/13376708/img-3966_1_orig.jpg)
(https://www.enkoo.nl/uploads/1/3/3/7/13376708/img-3965_1_orig.jpg)
