Author Topic: Planning the new bass  (Read 20006 times)
Re: Planning the new bass
« Reply #135 on: May 22, 2013, 07:02:56 AM »
OK, this is the final design.  I'm happy with the look and placement.
Just thought I'd tease you a little with the pickup I'm going to use..............................
It's the TV Jones ThunderBlade model, but the one I'll use is in a Gibson style ring for better height adjustment capabilities.
« Reply #136 on: May 22, 2013, 08:13:39 AM »
That's a pleasing look. To my eyes, it fits the body curve much better than your first drawing (above).
Have you decided on pickup placement?
« Reply #137 on: May 22, 2013, 08:50:56 AM »
I like it!  A tasteful and different choice.
« Reply #138 on: May 22, 2013, 09:50:35 AM »
I  like it.
with those pickups you may want and find a neck that is 2 1/4  wide versus the standard 2 1/2 fender too avoid extra wood past the string look/feel.
« Reply #139 on: May 22, 2013, 11:39:50 AM »
Thanks Dave.  The pup will be in the same spot as an NR TB, around 26.34"  IIRC.  Will remeasure before I rout it!
« Reply #140 on: May 22, 2013, 11:40:46 AM »
I  like it.
The pup should fit just fine where I'm locating it.  If not, we'll go to plan B.
« Reply #141 on: May 22, 2013, 11:41:16 AM »
Thanks Al.  All of the ideas and suggestions here helped me arrive at it!
    • Myspace page
« Reply #142 on: May 22, 2013, 11:59:15 AM »
 :thumbsup:
« Reply #143 on: February 10, 2014, 09:14:25 AM »
OK, I had some left over wood to use in the shop, so my first two prototypes will be made from that.  The first is a burly maple top on a solid maple body, the second is burly and flame maple on a solid mahogany body with a chamber on the top half of the body.
I'll start routing the control cavity and neck pockets later this week.
« Reply #144 on: August 08, 2014, 06:21:25 AM »
OK, I finally got my butt back in the shop.  I finish sanded all three prototypes and making them has been a great experience.  It's help me clarify in my mind how I want to make basses on down the road.  Technique and process are 80% of it!
Here are the three stained bodies and my headstock.  Not the best incandescent lighting in my shop.  I just might have to keep the semi-hollow for myself!
This one is semi-hollow as well but with carved out chambers.  Stain is red mahogany that will really pop and redden with a finish over it.  Will have a bolt-on neck.  Probably just going with oil on all of these so I can get them on the bay soon.
This is the semi-hollow cherry top/back with the bendable sides.  Stain is sedona red, one of my faves.  going to glue the neck in.
Solid body, all maple.  Ipswitch stain which is a light honey color.  Also going to do a set neck on this one.
So far, so good!!
** Hey Carlo, how have your set necks been working out?  Any issues with maple necks glued into mahogany bodies?
« Reply #145 on: August 08, 2014, 10:30:44 AM »
I'm really looking forward to seeing how they turn out!
Ipswitch stain?
From the vast and useless archives of my mind comes Danny Kaye, asking:
"Which witch switch should the Ipswitch witch twitch?"
Try that three times fast...
Then go on to:
"The pellet with the poison's in the vessel with the pestle. The chalice from the palace has the brew that is true!"
« Reply #146 on: August 08, 2014, 02:13:27 PM »
Ipswitch stain?
Then go on to:
Ah, the court jester, no?  Ipswitch is just a color name for a Minwax stain.  Fancy way of saying light tan!
« Reply #148 on: August 08, 2014, 03:07:58 PM »
Looking good, Doc!  I haven't had any problem with maple glued into mahogany.  How are those Eden necks?
« Reply #149 on: August 08, 2014, 04:34:59 PM »
Very nice...
