I think one of the strengths of the JCS (and the DCJr.) is that it's easy to get used to it, if you normally play a more Fender-style bass. The necks, the middle pickup. It's easier changing from P top JC than changing from P to SG Bass.
This bass is quite easy too, with a very narrow J-style neck. The JCS is more P. Also your thumb 'falls' on the split pickup immediately and you feel at home. Having said that, the JCS is hollow and long scale, while this one is semisolid and short scale, so soundwise it's very different.
The pickups are wider than P's, but I can imagine the chrome cover will fit a normal split P. You still have the rings then. So active EMG's might suck all the character out of it if you want.
This example has a beautiful dark fretboard with a fine stripe. I like the binding/dots combination.
