Author Topic: Speaker jacks  (Read 2699 times)
Re: Speaker jacks
« Reply #15 on: June 12, 2015, 04:38:17 PM »
I have had 1/4" plugs blown right out of the jack in the speaker cab from the sound pressure waves.   I'm sure others have also.  Not the best thing for a tube amp.  Don't have much experience with Speakons so nothing to add there.
Dang!  I take it those weren't ported cabs.  They also had a lot of speaker excursion going on.
Never had that happen, personally.  Impressive.  Probably very loud.
Re: Speaker jacks
« Reply #16 on: June 12, 2015, 08:24:45 PM »
I've never had that happen either. Can't imagine it happening with a ported cab.
OTOH there's nothing that hard about using a Speakon connector.
FrankieTbird
Re: Speaker jacks
« Reply #17 on: June 13, 2015, 09:52:55 AM »
No, not a ported cab.  Probably only happens with sealed cabs.
Re: Speaker jacks
« Reply #18 on: June 13, 2015, 06:52:09 PM »
They're just annoying to wire up and cost a bit much.
Re: Speaker jacks
« Reply #19 on: June 16, 2015, 06:06:17 PM »
  I hate speakons. Over engineered  nuisance ! My Orange TB500 uses them, I have adaptors yo run my 1/4" outfitted c as b.
Re: Speaker jacks
« Reply #20 on: June 16, 2015, 06:10:28 PM »
    I can't tell you how many times I have had road  crew,sound men or whoever mucking around behind my rig and tip my cables out. Usually easily repaired with a soldering iron. Can't do that with Speakons.
Re: Speaker jacks
« Reply #21 on: June 17, 2015, 04:59:28 AM »
I'm not even sure how that's possible unless its a shallow mount (standard bushing jack, vs long so as to be mounted in the cab wood directly) in one of them press fit jack plates (or maybe old, decaying, and low quality wood; I've seen cheap sealed 1x15s made out of such flimsy particle board).  Jack plates are horrible for a million reasons.  Without a jack plate, just put a larger washer under the nut on the inside and problem solved.
Re: Speaker jacks
« Reply #22 on: June 18, 2015, 03:15:17 AM »
The Speakons that I have can be connected using just a small screw driver. I find that a lot easier to fix when you're on the road. I don't always have a soldering iron at hand.
Re: Speaker jacks
« Reply #23 on: June 18, 2015, 04:51:11 PM »
+1
Easiest connection in the world to wire up and make you own cables.
Re: Speaker jacks
« Reply #24 on: June 19, 2015, 10:51:33 AM »
Assuming that you trust screw terminals on things that move and get yanked/generally abused (I don't) vs static things like the back of patchbays and internals of rack gear (e.g. euroblock).
