Author Topic: 1957 Gibson EB1 - Parts  (Read 1406 times)
dc10bass
« on: November 19, 2016, 01:39:51 PM »
Group...
I have a '57 EB1 that needs a few things;
(Not necessarily look for vintage parts right now)
Control Cavity Cover (+2 screws)
*Will most like make one, does anyone know where to find a similar "brown" colored material.
Control Knobs
Input Jack Plate (+4 screws)
Also need various Screws (most are either stripped or rusted)
Pickup cover (4)
Strap Button End Plate (4)
Any input is appreciated, Thanks!
« Last Edit: November 19, 2016, 01:46:15 PM by dc10bass »
www.talesofcream.com - A Tribute to the Music of Cream
www.facebook.com/LIVETHEWHO - The Who Tribute
Re: 1957 Gibson EB1 - Parts
« Reply #1 on: November 19, 2016, 01:55:56 PM »
The plastic components were made of bakelite. All parts sells amber speed knobs that should be in the ballpark. Screws should have a modern day available equivalent. The input jack plate might be tough to find or just find a friend at a machine shop to help. Good luck!
dc10bass
« Reply #2 on: November 19, 2016, 02:08:26 PM »
Yes, I knew the pickup cover was, didn't know about the control cavity cover.
Quote
Agree
Quote
The input jack plate might be tough to find...
Seems I should be able to use a standard Gibson jack plate (black), wasn't sure if the screw holes line up properly.
« Reply #3 on: November 19, 2016, 02:18:35 PM »
I'm assuming the control cavity cover is the same material as the pickup cover and pickguard as it makes sense from a manufacturing standpoint. Lucky you've got the earlier bar bridge though. Replacing an evertilt on the reissue isn't something I'm looking forward to figuring out.
« Reply #4 on: November 20, 2016, 10:44:32 PM »
Pickguard Heaven (Chandler) lists brown gloss (single layer) and brown/cream/brown, and they do sell sheet material. No photo of the single layer brown, you'd have to check with them to see if it's dark enough. It's apparently not brown tortoise, since they list that separately.
Bionic-Joe
« Reply #5 on: November 21, 2016, 09:23:03 AM »
I think there is a company from the UK or Japan that sells relic Les Paul Parts. They make repro Brown control covers. They may have the material...Or just buy a new Gibson Historic one and cut it down.
