Author Topic: '78 P string height problems  (Read 11207 times)
Re: '78 P string height problems
« Reply #15 on: October 01, 2010, 03:01:43 PM »
if the shim doesn't work trying sinking  the bridge into the body.  can't go to far down or you will have to route channels to get the string balls to sit right.
jim
Iome
« Reply #16 on: October 02, 2010, 12:32:40 AM »
No, i'm not going to route the body. Anyway, i shimmed (if you can say that) it last night with a business card. I've cut it to fit the end of the pocket until 5 mm behind the rear screws. It helped, i've got a pretty nice action now, but the saddles are still at their lowest. Tonight i'll try to fold a card and cut it to fit like the first, so i have some height left to move the saddles, i'll make some pics for some comments/advice. Thanks
« Reply #17 on: October 02, 2010, 12:58:46 AM »
You've got to shim harder then. Shim is not a sin, brotha! :D
If I were you, I'd put a straight thin of wood under the whole neck route, and then put a shim on the bridge side of the neck route. I'd call it "a shim sandwich". ;)
Iome
« Reply #18 on: October 02, 2010, 04:10:06 AM »
AMEN BRO',
i was thinking about usinng a straight piece of wood to raise the whole neck...hmmm...donno, i'll try tonight when the kids sleeps..
« Reply #19 on: October 02, 2010, 04:47:41 AM »
Have you ever seen a business card made of wood? Some cabinet makers and carpenters use them around here. Real thin shaved piece of wood for a card. I think they would be perfect.
Iome
« Reply #20 on: October 02, 2010, 05:24:55 AM »
I've never seen a business card of wood, but i know that carpenters has some thin wood they use for similar purposes. Last night i looked for some  veneer wood down in the basement, but couldn't find any, i know i have some, somewhere.
« Reply #21 on: October 02, 2010, 10:50:36 AM »
Shim it!!  Adding a shim is standard procedure - some basses come from the factory with shims.  I have never understood why some folks think they are bad.  They're just one of the necessary tools.
Iome
« Reply #22 on: October 02, 2010, 10:58:53 AM »
i know Pilgrim, but you know people won't buy a bass that need something between neck and body. What bothers me is that my bass hasn't an angle issue between neck and body, the neck is just too thin...
« Reply #23 on: October 02, 2010, 11:17:13 AM »
Don't Ask Don't Tell.  You have a nonstandard neck, it obviously came from Fender that way. They shimmed it, somebody bought it.  Hell, I've got shims with Ibanez STAMPED on them.
Shim Ain't No Sin...It's a design feature ;D
« Reply #24 on: October 02, 2010, 12:37:58 PM »
Credit cards make extreme shims, too...
I had a couple of sixpences (small obsolete British coin used by Brian May as picks) in my first to try and sort out neck issues...
There is an old expression... what the eye don't see...
As long as she plays well what's the problem...? ;)
Iome
« Reply #25 on: October 02, 2010, 12:50:07 PM »
Ok, I must find an old american business card or, even better, a fender card from the seventies, at least if the buyer finds it i'll tell him it's an extra value, a vintage shim  ;D Now theres a card in from the baker in front of my office...
« Reply #26 on: October 02, 2010, 12:51:45 PM »
I've got some cardboard boxes in the shed... :P
« Reply #27 on: October 02, 2010, 07:41:46 PM »
Since when won't they? You would be surprised. And that's with basses and guitars that were made to go together. In your case, you have a neck that isn't the thickness that was meant to go with the body, so all the more reason to shim.
Hornisse
« Reply #28 on: October 02, 2010, 07:47:21 PM »
Back in the '70's I used one of these on my P bass.  Worked like a charm!  Put the flat side towards the body and it was a Fender Thin pick.
« Reply #29 on: October 02, 2010, 09:30:02 PM »
I respectfully disagree.  First, there is no need to tell them, because it's a normal adjustment.  Second, they're not going to know. Third, it's not really a relevant concern - because it's a normal adjustment and therefore unremarkable.
I would not mention a shim in the neck of any of my basses to a buyer - because it's nothing worth mentioning.
If there were a structural flaw in the bass that some kind of unusual shim was correcting, I'd mention it - but a normal shim is simply not remarkable.
