Author Topic: CURRENT CATALDO  (Read 143590 times)
Re: CURRENT CATALDO
« Reply #105 on: February 05, 2014, 04:21:54 PM »
Thanks for all the kind words, guys!
I'm still using Mohawk products, Bill.  But I've started using TCP catalyzed automotive polyester primer under solid colors.  It builds and fills great.  I've also used Reranch for some color coats, I take the paint out of the rattlecan and put it in the gun.  But I'm switching to buying quarts of acrylic lacquer from TCP global.  Each quart will color coat at least 10 basses and they'll mix any color ever used on a car.  I expect to have a lot of leftover paint.  I basically have an up charge that covers the cost of the custom color which varies between $50 and $100.  Reds are the most expensive, generally.
The sunburst was done on natural mahogany, so it's only one color step.  I mixed a burgundy/brown dye from red, yellow, and blue ultra penetrating stain and shot it with my regular gun, only with low pressure and tight round pattern.  Here's a how to from Youtube
I used a turntable with the bass flat and did one side then the other.
There can be a pretty steep learning curve.  I suggest you convince Scott to give you some tips!  Preparation of the body is 90% of getting a great finish with the least amount of effort.
Re: CURRENT CATALDO
« Reply #106 on: February 06, 2014, 10:40:09 AM »
My work is nowhere near yours Carlo.
Re: CURRENT CATALDO
« Reply #107 on: February 06, 2014, 04:22:30 PM »
Thanks for the compliment, Scott, but I remember how baffled I was with just the basic gun controls when I started.  It would have helped a lot to have somebody demonstrate that stuff, it does take a while to master.  I don't think you can learn the fine line between a great wet coat and a mess without sanding some runs.
Re: CURRENT CATALDO
« Reply #108 on: February 06, 2014, 04:27:03 PM »
Sorry... couldn't resist... ;)
Re: CURRENT CATALDO
« Reply #109 on: February 12, 2014, 09:19:19 AM »
Blocked and Bound for Barstow.
Stjofön Big
Re: CURRENT CATALDO
« Reply #110 on: February 12, 2014, 01:26:26 PM »
Sketasnögg, as we Swedes tend to put it! Or, if you prefare: Fuggin' beauttifulll!
Re: CURRENT CATALDO
« Reply #111 on: February 13, 2014, 09:46:02 AM »
You're putting a black pickguard on that one, right?  ;)
Re: CURRENT CATALDO
« Reply #112 on: February 13, 2014, 10:09:22 AM »
Yep!
Here's the EBird in a Dean case.  It's huge but the Epi Explorer cases are no longer available.  This one doesn't require any mods.  I used an Ebony board neck after I received one with a stripey rosewood board I didn't want to use with a 'burst.  Body gets buffed and bass assembled tomorrow.  This is closer to the true color.
Re: CURRENT CATALDO
« Reply #113 on: February 13, 2014, 10:19:32 AM »
Or ´dødsfet ´like we say in Norway :)
Re: CURRENT CATALDO
« Reply #114 on: February 15, 2014, 05:16:31 PM »
Thanks for the language lessons, guys!
Buffed and ready to rock.
Lens flare was a happy accident.  Here's my photo setup.  Bright sun in the shade of my portable garage.
    • Myspace page
Re: CURRENT CATALDO
« Reply #115 on: February 15, 2014, 05:20:48 PM »
Damn that turned out beautiful!!!!!!!!!!
Re: CURRENT CATALDO
« Reply #116 on: February 15, 2014, 08:39:26 PM »
Awesome looking work there and more Cataldo trees too.
Re: CURRENT CATALDO
« Reply #117 on: February 15, 2014, 09:52:37 PM »
   Beautiful as always!
Re: CURRENT CATALDO
« Reply #118 on: February 16, 2014, 05:26:34 AM »
As above... can't add any more... 8)
Re: CURRENT CATALDO
« Reply #119 on: February 16, 2014, 07:54:49 PM »
It reminds me of the explorer-bird Entwistle played on the "Who Are You" bit of The Kids Are Allright.    Only much prettier.
