Author Topic: Peelings. Wo-oh-oh-ooo peelings... (BaCH NR and a stripper)  (Read 38397 times)
Re: Peelings. Wo-oh-oh-ooo peelings... (BaCH NR and a stripper)
« Reply #75 on: September 02, 2009, 07:14:42 PM »
Yeah, I would try some 320 for the edges.  Grain filling is an art - rub off too much you just have to go back and do it again - leave on too much you sand for ever - rub it down too soon you just wipe it out of the pores >:(  I'm down to three coats on ash and a two, usually, for mahogany.  The filler tends to load the sandpaper down so switch it out often, of course you figured that out by now :P.
Or you could be like Gibson - hit it with one coat of filler, sand it and paint it ;D
« Reply #76 on: September 03, 2009, 04:16:33 AM »
I learned to use two on my mahogany projects and using it liberally (yes more sanding, but better sealing)
« Reply #77 on: September 03, 2009, 05:55:26 AM »
When it comes to edges, I barely sand mine as they typically don't show a lot of oragne peel.  Don't ask me why!  And yes, going to s 320 or 400 for edges is probably a good idea if you have it.  Better safe than sand through!
« Reply #78 on: September 09, 2009, 01:35:35 AM »
Well the grain filling went good, ended up using two coats.  I sprayed the sand and sealer when that was done.  That kinda surprised me at first - I guess I was expecting something more like a high-build primer, but what came out looked more like a thick, semi-gloss clearcoat.  I've never worked with it before this.  Cool stuff, since the sheen helped reveal any imperfections:
I had one issue with the veneer on the back @ the upper horn.  I'm not sure if it was the block sanding thinning it too much, or if the stripper caused it to lose adhesion in a couple small places - almost like bubbles, or hollow pockets under the veneer.  I carefully slit the veneer in those spots with a thin razor, worked in some CA glue, and pressed it back down with a plastic spreader (resistant to the glue).  This seemed to work out, and just required a touch of filler in those spots.  Whoops!!  :o
After leveling the front, back, and sides I sprayed the first primer coat.  Here it is now:
Hey - it looks just like it did when I started!  ;D
« Reply #79 on: September 09, 2009, 04:50:42 AM »
Looks great!  When are you shooting the color?  Wating for the humidity to drop? ;D
« Reply #80 on: September 09, 2009, 05:05:38 AM »
Looks great!  Nice work!  Can't wait to see it finished.
« Reply #81 on: September 09, 2009, 08:02:48 AM »
Ha! That's what I was thinking! That's gonna be one sweet bird when it's done.
« Reply #82 on: September 09, 2009, 11:32:49 AM »
Thanks all!
I found a blurb with some (hopefully valid) tips to avoid blushing here:
http://www.woodweb.com/knowledge_base/Avoiding_Blush.html
Based on that info, the conditions are right on the edge at the moment.  We've been getting some Houston weather! ;)  Any other week I'd be coming inside from working on it dried up like a piece of jerky with a nice svelte tan!  ;D
I'm waiting on the pickguard now - should be here any day.  Once that arrives, I can fit it and finalize the position to route for the second pickup.  I'll probably do the routing and drilling, then resume with sanding and a second primer coat, and then start into the color coat.
« Reply #83 on: September 09, 2009, 01:30:43 PM »
Overdid the spray-tan, Joe...  ;D
Nice for the thread to get back to the topic... ;) (guilty as charged for assisting in inciting a riot; may I ask for 2 billion other offences to be taken into consideration...?)
Looking good...  8)
« Reply #84 on: September 09, 2009, 04:30:16 PM »
Hey I like off-topic.  Drives people nuts, but generally bodes well with my attention deficit traits.   ;)
Gotta use up that can of amber-tint somehow!   ;D
« Last Edit: September 09, 2009, 04:35:59 PM by chromium »
« Reply #85 on: September 10, 2009, 01:57:44 PM »
Sorry... what did you say, er... Joe, isn't it...  ;D
« Reply #86 on: September 16, 2009, 03:54:02 PM »
How's the fin going, Joe...?
« Reply #87 on: September 16, 2009, 04:03:27 PM »
I'm kind of in a holding pattern at the moment.  I have a 'guard coming from Terrapin, and I'm just waiting on that to arrive so I can be 100% sure of that second pickup's final position.  I'd really like to do the routing while its still primered... just in case!
« Reply #88 on: September 17, 2009, 01:30:13 PM »
I'm doing my routing before anything else... just sourcing the timber, which has not been as easy as I thought...  ???
« Reply #89 on: September 21, 2009, 04:47:51 AM »
Saw it was 110 degrees in AZ.
Looking great Joe.
