Author Topic: CURRENT CATALDO  (Read 147849 times)
Re: CURRENT CATALDO
« Reply #405 on: January 27, 2016, 03:43:14 PM »
New look for 2016.  Black power!
Trans Red over poplar, wide 5 17/8" at the nut, ebony board, Hipshot 'Y' tuners, ABM bridge.  Black ThunderBuckers and rings go in tomorrow.  'Speedier' knobs, no number with drilled and filled tops.  Red 'bird transfer from Larry Verna.  Pickguard red stripe is sharpie over white.  Off to the land of the wooden shoes next week.
Basshappi
Re: CURRENT CATALDO
« Reply #406 on: January 27, 2016, 04:28:30 PM »
Oh my!
The Bloodbird!
Re: CURRENT CATALDO
« Reply #407 on: January 27, 2016, 05:04:31 PM »
Wow Carlo THAT ROCKS
    • Myspace page
Re: CURRENT CATALDO
« Reply #408 on: January 27, 2016, 09:23:01 PM »
Stunning!!!
Re: CURRENT CATALDO
« Reply #409 on: January 28, 2016, 04:05:28 AM »
If only Gibson could create something that beautiful.
Re: CURRENT CATALDO
« Reply #410 on: January 28, 2016, 08:15:23 AM »
Man, you always have something cool up your sleeve, don't you? Looks great!
Re: CURRENT CATALDO
« Reply #411 on: January 28, 2016, 02:42:14 PM »
I can only echo Bill's comments... 8)
Re: CURRENT CATALDO
« Reply #412 on: January 28, 2016, 04:38:05 PM »
Thanks, Guys!  I really appreciate your encouragement.
Black matte powdercoat over nickel silver.  I'm pretty satisfied with my first attempt.  I'll try gloss next time.  Tough stuff!  I tried to chip it off with an exacto knife, no way.
Also did the jack nut and washer, impossible to find black Switchcrafts.
Strings are GHS Progressives.
http://www.ghsstrings.com/products/11284-bass-progressivestm?category_id=1964696-progressivestm
Magnetized tungsten. Note the taper core B and E strings at the bridge saddles.  GHS contacted me a few months ago about using their strings and were nice enough to send me samples, including a custom 12er set to my spec.  I like the Progresives a lot.  Very smooth from bottom to top.
Re: CURRENT CATALDO
« Reply #413 on: January 28, 2016, 09:31:52 PM »
Thunderbuckers and an ebony board .... ohhhh man. I want to hear this so bad.
Re: CURRENT CATALDO
« Reply #414 on: January 29, 2016, 12:18:54 PM »
I used to use those "style" of strings (central core on bridge only) on my headless (Mark King Rotos) but I tended to snap them so never went back to them... don't have any modern experience of them, mind you...
Re: CURRENT CATALDO
« Reply #415 on: January 29, 2016, 12:51:07 PM »
Looks to me like your chops for composition and the obvious building skills have exploded Carlo.
But I do miss the trees ;D
Re: CURRENT CATALDO
« Reply #416 on: January 29, 2016, 01:45:55 PM »
That looks fantastic!
Carlo - did you do the powdercoat yourself?  If so, just curious what kind of setup are you using?
The results look good.
Re: CURRENT CATALDO
« Reply #417 on: January 29, 2016, 02:51:44 PM »
I used a Harbor Freight system, around $54 with a 20% off coupon.  Also used their powder, $7 for a pound.  They have four colors and the black only comes in matte.  Bought a toaster oven for curing at Walmart for $18, more than adequate.
http://www.harborfreight.com/catalogsearch/result?q=powder+coat
You need a compressor but it only requires around 10 psi.  There are lots of You Tube tutorials.  Quality powders are around $15 per pound, that will do a lot of coating.
If you screw up you can easily remove the finish with rattle can paint remover.  I did a few test scraps and the actual parts came out with no problems.
Re: CURRENT CATALDO
« Reply #418 on: January 29, 2016, 03:11:06 PM »
Awesome- that is right up my alley.  I've made good side money with my Harbor Freight tools over the years  ;D
I had a prototype panel machined by Front Panel Express a while back, and their cost to powder coat is very high (per piece).  Looks nice, but I ended up going with anodized aluminum on the "production" units because of that.
Thanks for the tip.
Re: CURRENT CATALDO
« Reply #419 on: January 29, 2016, 03:57:38 PM »
You're welcome, Joe.  I've also made a lot of money with Harbor Freight tools going back to the mid 80s when they were a 6 store chain/mail order business.  They've always been great value for the price.
