My crazy summer is wound down now, I got a couple minutes to work on this again. Dave gave me a bridge to replace the ugly one it used to have (thanks again!) I used the ultra-precise method of tracing around the old one, putting the new one in it's place and drilling the new holes. (both bridge plates were the same size, within a couple MM anyway) Either I sneezed when I drilled (5 times, though?) or somebody really messed up where the original one was installed because when I checked it, it was WAAAY off centered.
I don't remember it being this off when I bought the thing. I took it back off, got out some string and the tape measure and marked out where it should be (34" from the nut anyway) I plugged the new set of holes and will measure it all up again BEFORE I drill some more.
This would be why I try to fix (notice I said, "try"
) $99 instruments and not anything that was valuable. Of course if it had cost more, it probably wouldn't need any work to begin with, right?
I at least got the cavities shielded. I've been working on rewiring it, but since I never worked with pickups with 3 wires before, it's going about as well as the bridge install.
