Yep. I built a bass. Actually I built an almost completely hollow bass. Block under the bridge and two full height braces running from the bridge block parallel to the strings just outside the pickups to the neck block. (similar to how I build Acadian and Daylighter Supreme). TV Jones Thundertrons, Spanish Mahogany body, maple cap, graphite reinforced maple neck. 32.5" scale.I actually built two. This one is the same specs as the green one except more semi hollow with a full center block tail to tip. Same material and pickup combo.The Thundertrons are freaking incredible. Both basses are amazing with the green one being my slight favorite. They sound amazing, have that motown hollowness/thud when you want but seem to have the attack of the solid versions. Balanced perfectly too surprisingly with the green one being 6.5lbs!
