JJ makes good tubes, period. The marketing tiers that they use typically have some basis in tube performance ratings, unlike some other tube marketing companies. Hiwatts are pretty hard on bad tubes but good tubes biased properly in that amp will have the same life as most transistors in good s/s amps and will certainly outlive an amp with any kind of switching, either in the power supply or the output stage.
