Author Topic: Pin Router Fun, control cavity routing  (Read 682 times)
« on: May 04, 2011, 05:40:37 PM »
Finally got the three depth turret stop figured out on my Onsrud.  Also it has a switched outlet that turns on the shop vac with the router.  Unfortunately that pulls too many amps and slows down the router causing the bits to dull quickly.  Now I use a separate circuit for the vac and turn it on manually.  BIG IMPROVEMENT.  This is Jim's JAEbird II which will have ThunderBucker pickups.  Since he owns a Lull I'm looking forward to seeing how they stack up against each other.
Drill about 3/8"into the body
Dowels hold template in place
routing for cover plate
Insert used to mark cavity boundaries
Hogging cavity
Insert used for routing cavity
Done Deal, 1/4 " thick cavity top.
Re: Pin Router Fun, control cavity routing
« Reply #1 on: May 04, 2011, 06:19:21 PM »
Nicely done!
