Gear Discussion Forums => Bill's Shop: Projects, Mods & Repairs => Topic started by: wellREDman on March 12, 2015, 07:08:34 AM
I have a bass that has developed an electronic buzz that goes away when I'm in contact with the strings, Ive had a look inside but cant see any obvious loose wires, its an active single pickup.
any ideas what might be causing it?
A quick check could involve opening the cavity, and move wires with something pointy whilst being connected to an amplifier.
This sometimes isolates the problem, if there is a loose connection or something. The wires to the jack is common, cut off 5mm or something and re solder. If still buzz, re solder all connections - checking the wires with a diode tester for continuety as well.
If it's still buzzing, you might have to check each component thoroughly.
Of course you have tried to replace/tested you instrument cable first.. 8)
