Author Topic: CME limited edition SGs - collecting for fins and pickguards  (Read 3602 times)
Re: CME limited edition SGs - collecting for fins and pickguards
« Reply #60 on: January 19, 2022, 06:04:05 AM »
Most of my stuff has flats , I like TI Flats on Rics & Pbasses , I keep fresh Slinky’s on the Ray . The Unicorn has DR Black Beauties . The Samurai has TI’s too . For short scale basses I generally prefer a stiffer flat and have bounced between LaBellas and GHS . I’ve been keeping BriteWires on the SG and DC Jr . The SG will probably get flats in the future . My Longhorn still gets most gigs , it’s still got the factory rounds on it from 98 or so . It’s got a great woody thump . I’m hoping my Dano DC will develop the same woody thump , it’s got older BriteWires . Spirocores on the upright , Thunderguts on the Ashbory and uke . I seem to buy strings every other month or so . Next set will probably be for the Bass V1 , I’ll get the newer Fender set with the heavier E . I’ll stick with rounds on that .
I lump strings into three groups , rounds , flats , and then ancient dead rounds , that have that flat wound thump . I’m not including the rubber ones for the ultra short scales .
« Reply #61 on: January 19, 2022, 09:07:35 AM »
I've used string cutoffs too, but most nut materials are softer than frets.
Nickel strings on nickel frets will make an impact over a decade or so easily.  Even water wears away the rock.  Sure, with steel strings it's just more of a threat, but either way it happens if you keep and play the bass enough.  Nobody is saying you can saw through a fret in 10-15 minutes like you can a cheap plastic nut (as is it takes a surprising while - roundwouunds aren't the most efficient file and I wouldn't use them to slot a fresh nut so much as to widen/deepen existing slots a smidge especially when trying a new string gauge).
« Reply #62 on: January 19, 2022, 03:15:10 PM »
My '64 EB-0 has Labella Deep Talkin' Flats, and they've aged nicely after nearly 10 years installed.  It sounds the strings were made for that specific bass.
But then, I think Labella DTFs are the right flats for almost any bass.
« Reply #63 on: January 19, 2022, 11:30:09 PM »
All depends on your technique. I've always used a light touch on bass and guitar, but some guys -- especially guitarists -- can chew up frets in short order using nickel rounds.
Stainless steel round wrap wire is much harder and the surface is like a bunch of little files. Some brands are finished much better than others, and that makes a difference.
« Reply #64 on: January 19, 2022, 11:43:08 PM »
"I've always used a light touch on bass and guitar ..."
People too, not to forget!  ;D
