Author Topic: 1995 custom shop Thunderbird  (Read 1420 times)
Re: 1995 custom shop Thunderbird
« Reply #1 on: December 03, 2020, 01:21:43 PM »
That's a nice crack on the back of the headstock at the neck.
« Reply #2 on: December 03, 2020, 03:03:16 PM »
Yeah, but it comes with fresh roundwound strings, so it's definitely worth $3300.  ;)
« Reply #3 on: December 03, 2020, 03:41:55 PM »
That could be just the finish checking where the laminate seams run
« Reply #4 on: December 03, 2020, 04:29:41 PM »
  Just a tarted up 90's bird. Lipstick on a pig.
« Reply #5 on: December 03, 2020, 04:44:11 PM »
Shouldn't be the cover mounted in the other direction?  :mrgreen:
« Reply #6 on: December 05, 2020, 02:37:49 PM »
This. I'm pretty sure the "limited edition" sticker refers to the ebony board. That's it. My black 2002 "limited edition" had that and an MOT pickguard (with the stamped bird). I added chrome pickups and hardware, but never claimed that stuff was original. I think if this had been an actual, commercially available model in 1995, at least ONE of us would have known about it (or talked about it at the Dudepit or here).
« Reply #7 on: December 06, 2020, 06:41:35 AM »
Yes, it should.
« Reply #8 on: December 06, 2020, 04:26:19 PM »
Where's the serial number? I suspect a refinned back after a headstock incident. The Limited Edition decal could be a retrofit after all.
« Reply #9 on: December 07, 2020, 04:02:25 PM »
Looking at this view, below the E on the sticker and to the left, I would say it is a repaired headstock.
« Reply #10 on: December 08, 2020, 07:56:12 AM »
These covers and the vintage look pups just don't look right with the small post-'87 headstock (which has everything going for it balance- und stability-wise, though the larger vintage headstock looks gorgeous of course).
« Reply #11 on: December 08, 2020, 08:27:41 AM »
I also think it's weird that they kept the Schaller M4 tuners.  ???
« Reply #12 on: December 08, 2020, 09:37:31 AM »
Please explain your reasoning for this - if that were the case shouldn't the crack be running in the perpendicular direction?
« Reply #13 on: December 08, 2020, 11:10:14 AM »
That ties in with the "let's make it less likely to break off"-concept though, smaller tuners equates less leverage and general getting-in-the-way.
« Reply #14 on: December 08, 2020, 11:43:42 AM »
 The whole thing is weird - beyond Gibson weird. Heavy corrosion on the pups and tuners, strange.
