Main Forums => The Bass Zone => Topic started by: PhilT on January 16, 2008, 05:53:54 AM
Has anyone tried multi-track (ie more than 2 tracks) recording onto a PC? I assume that needs a Firewire interface, rather than USB. Are there any (not too expensive) options for doing this?
I use Garage band (standard on all Mac's) and a $69 M-Audio USB interface & record direct.
If you are on a PC can't you get a free copy of Pro Tools lite?
I want simultaneous multi-track recording. That M-Audio box you use only sends two channels at a time to Garageband, doesn't it?
I've just been looking at the M-Audio FastTrack Pro, which as far as I can see sends 4 channels to the PC via USB, but is somewhat more expensive than your $69 box. If I can convince myself it's worth spending 150 pounds on, that might be the solution.
there are many multi port USB interfaces , but cost a lot more
I use a M-Audio 1814 8in/4out interface (http://www.musiciansfriend.com/product/MAudio-FireWire-1814-Computer-Recording-Interface?sku=709201&src=3WFRWXX&CAWELAID=26049446). I got it off Ebay for $300 USD - mainly just in case I needed the extra I/Os for something (recording drums, for example). What I have found for most of my stuff is that I typically only record 2 tracks simultaneously. I probably would have been fine with something smaller - like the M-Audio 410. I've been happy with this interface so far, BTW. The built-in preamps are kind of meh, but the nice thing is that you don't have to use them. I use an outboard pre, and that sounds much better.
Most of the audio interfaces on the market that use firewire operate at firewire 400 spec (400 Mbits/sec). While USB2 (480 Mbits/sec) actually signalls faster than FW400, FW400 can be better at sustained data transfers since it uses its own processor - unlike USB which shares your computer's processor. Given this info, it might be a better bet to opt for firewire over USB if you have a choice - but the question of whether or not you *need* firewire just depends on what you are doing, how fast/powerful your PC's processor is, etc...
