Gear Discussion Forums => Bill's Shop: Projects, Mods & Repairs => Topic started by: shadowcastaz on February 12, 2016, 02:15:21 PM
Title: Double Muds!
Post by: shadowcastaz on February 12, 2016, 02:15:21 PM
I have 2 mudbuckers that need to be checked & re wired. Any recommendations where I can send?
Title: Re: Double Muds!
Post by: Alanko on February 12, 2016, 03:59:08 PM
Curtis Novak?
When you said Double Muds I had this in mind...
(http://i6.photobucket.com/albums/y220/Meddled/20130527_190507_zpsaqoimsyy.jpg)
Post by: Pilgrim on February 12, 2016, 04:19:20 PM
Much chromey-ness there!  I approve.
Post by: Granny Gremlin on February 12, 2016, 04:23:22 PM
Bah; too far from the neck.
Post by: Dave W on February 12, 2016, 05:48:06 PM
I've never used Curtis Novak but he has a great reputation and he knows mudbuckers. He offers his own vintage reissue plus a couple of variations, and he can rewire yours or rewind however you want.
Post by: dadagoboi on February 12, 2016, 07:14:07 PM
Novak's 'vintage reissue' is nothing but a rewound artec/epi pickup.  I've A-B'd them visually.  Sounds nothing like a '60s mudbucker, very nasal...IMO
Customer regretted having me put one in this bass.  Sent it back for a ThunderBucker transplant.
(http://i976.photobucket.com/albums/ae241/cata1d0/0050/P1050186_zpse096b0e2.jpg) (http://s976.photobucket.com/user/cata1d0/media/0050/P1050186_zpse096b0e2.jpg.html)
Post by: amptech on February 13, 2016, 02:02:32 AM
I rewind pickups at $50 per coil. I am located in Norway and shipping might cost a bit, so you are probably better off if you find someone near you. I've done a few mud rewinds, both 'downscaling' and vintage spec. At this very moment I'm winding one I will try to match with a classic P bass in neck position.
Post by: Bargeon on February 13, 2016, 01:14:15 PM
Making you The Mudbucker Proxy ?
Post by: Dave W on February 13, 2016, 04:13:31 PM
He may buy pickup components from the same supplier as Artec but I seriously doubt he would risk his reputation by buying an Artec or an Epi and rewinding it. It wouldn't makes sense anyway, it would take more time to undo and clean one up than to wind a new one using new components. If I were in your shoes, I'd be very careful about saying that without proof. You and he are both small businessmen with reputations to protect.
I haven't heard his vintage reissue but I do like the sound of his replacement EB-AA Fatbucker (http://curtisnovak.com/pickups/EB-AA.shtml) as heard in this video.
https://www.youtube.com/watch?v=_vYiNpBAr3Q
Post by: Highlander on February 13, 2016, 04:30:22 PM
Key question... what's wrong with the originals...? Not that hard to strip them down to check, especially if yo are going to the expense of e rewind... I split the coils on the MB our Old Man supplied me for the PC...
Post by: shadowcastaz on February 13, 2016, 07:37:40 PM
I had new leads put on one of them and the other one needs new leads. I dropped the one I had done  so I may as well have it redone  because it does not read correctly.
Post by: dadagoboi on February 14, 2016, 04:16:30 AM
Thanks, I don't need any advice on this subject and have no rep to protect.  I'm 70 with both feet on banana peels.  As I said I've visually A-B'd them.  It's easy to rewind those pickups, takes almost no time to cut the wire off and there's no potting.  I'd do it the same way, $16 for components can't be beat.
I'm not casting aspersions on any of his other product, simply relating my experience with one of them.  Other than that my only problem is his supposed Gretsch 'cadillac green' restoration.  He used a metallic.
Post by: 66Atlas on February 14, 2016, 03:19:20 PM
Did the ever actually produce a ripper with dual mudbuckers or was that just a promo/prototype thing? Regardless I think that would be a fun build.
Post by: Granny Gremlin on February 14, 2016, 05:06:20 PM
I think it's just that Ripper pups are technically Jr Mud (sidewinders like the mudbucker and generally very similar internally - just the magnet type and windings/guage differ).
This:
(http://www.flyguitars.com/graphics/part21_3.jpg)
vs this:
(http://www.flyguitars.com/graphics/part25_2.jpg)
(pics courtesy of Jules' site).
Post by: Dave W on February 14, 2016, 10:24:53 PM
The mud comes from the extreme overwinding. There's nothing muddy about the sidewinder design. The Ripper and Bicentennial Thunderbird pickups aren't the world's clearest pickups but I certainly wouldn't call them muddy.
Others: the Lace Holy Grail Strat pickups are sidewinders and they're anything but muddy. Likewise with the Lace PS900 series. Bill Lawrence designed and patented a sidewinder guitar pickup before he worked for Gibson, and he later sold a version for steel guitar; it was bright. The Gibson Les Paul and SG Futura models from the Gibson 2014 line had what they called a P90-H in the neck position; like the Lace PS900, it was also sidewinder humbucker that looked like a P90. It sounds clearer than regular P90. No doubt there are others out there.
Post by: amptech on February 15, 2016, 02:27:50 AM
I did put that overwound sidewinder concept into a minihumbucker size build, and was blown away by the result. I did this because I was unhappy with the EB3 minihumbucker sound, and overwinding the stock pickup with thinner wire only made it slightly louder and it lost treble. Just an unplesant honk. A stonger magnet helped, but still poor sound (in my ears). And routing for a bigger pickup is out of the question. So I scaled down the mudbucker design and squeezed it into a minihumbucker cover. I aimed at 30K dcr but at just over 28K there wasn't room for more wire. I used two small alnico 5 bars (from mini humbuckers) and the only drawback was a 5mm gap between the base and the cover bottom. But the result was a very high output, high sensitivity pickup with lots of punch. It is the first pickup I have found louder than the mudbucker, although less bassy. It has decent brightness too. I'd say it would be a good business idea, if it didn't take five days to build :) I am still puzzled by it's relative brightness, it is definitely in the extreme overwound category.
Post by: Alanko on February 15, 2016, 06:35:20 AM
I've owned and tinkered both Artec and Epiphone mudbuckers. The Epiphone has tighter string spacing, in line with the neck position on the EB-family of basses. The Artec had wider spacing that suited a Fender, although the E string's excursion was still beyond the range of the magnets. The Epiphone was only wound to about 14 k ohms or so, whereas the Artec was around 36 k ohms or so, with the magnets mounted incorrectly and the coils wired incorrectly.
Your mileage may vary, but I don't think they are the same pickups.
Post by: Granny Gremlin on February 15, 2016, 07:13:46 AM
Yes of coarse, I did not mean to say that Ripper pups are muddy sound-wise, so much as they are the same basic design as the mudbucker, but underwound (by comparisson) and therefore smaller; hence the prefix "Jr."
Having a character adjective also be a pup name can be annoying in this way.
Post by: leftybass on February 15, 2016, 07:18:32 AM
I thought of this:
(http://img.photobucket.com/albums/v383/iamthebassman/EB2.jpg) (http://smg.photobucket.com/user/iamthebassman/media/EB2.jpg.html)
Post by: 66Atlas on February 15, 2016, 01:17:05 PM
I like the look of it on the EB2.
So I guess with the Ripper it was always intended to be a redesigned pickup.  I found the ad I was thinking of, to me it's a shame they never built it this way, I actually prefer the look of the chrome pups and smaller pickguard.
(http://i1142.photobucket.com/albums/n614/tlkroon/ripper74_zpsxnv5uvpd.jpg) (http://s1142.photobucket.com/user/tlkroon/media/ripper74_zpsxnv5uvpd.jpg.html)
I think the shirt might be even better than the bass though... ;D
Post by: FrankieTbird on February 15, 2016, 05:01:19 PM
Holy moly!  Who is that awkward looking fellow?
Post by: Dave W on February 15, 2016, 09:49:38 PM
I've seen that catalog photo before and assumed it was just a mockup for the photo shoot. A real bassist wouldn't have a bass face like that. He probably got dragged away from his regular job of underwear model for the Monkey Ward catalog.
Jake, I didn't mean to call you out over the mud description, just pointing out to anyone who didn't already know that the design isn't necessarily muddy.
Alanko, I didn't know about the difference in string spacing between the Epi and Artec but they definitely don't sound anything alike. The Epi should read about 2K max. I didn't know about the Artec coils being wired incorrectly but one look at it (uncovered) and you can see the magnets are mounted wrong, they all need to be facing the steel blade the same way.
amptech, you know a lot more about pickup design than I do, no idea where the brightness came from. OTOH I'm sure you know that you can get 26K using thinner wire on a smaller bobbin and it won't sound like a Gibson mudbucker.
Carlo, you're entitled to your opinion, of course, but I don't think Curtis Novak is rewinding Artecs or Epis.
Post by: Alanko on February 16, 2016, 03:47:32 AM
I'm wondering now if there are different Epiphone mudbuckers. Mine came from a bolt-on EB0; the cheapest Epi on the market. It might be a different pickup in the set-neck EB-3s, or the Elitist (sp?) models?
I would be surprised if Novak is using upcycled Epiphone and Artec parts, simply because he reverse engineered the Bi Sonic pickups and developed all the parts himself. He also makes reproduction WRHBs with threaded magnets, whereas other builders settle for a Generic PAF-type design and simply style the pickup cover to look the part.
I wonder if there is only so many ways to skin a cat, and that most sidewinder replicas are going to look roughly the same? There was nothing on my Artec or Epiphone pickups that identified the manufacturer, and the Artec was topologically correct with the Gibson originals, albeit with the manufacturing errors.
Dave W, 12 k (I think that is what you meant to type?) sounds about right. I measured it a year ago and memories get fuzzy.
Post by: Granny Gremlin on February 16, 2016, 07:35:43 AM
Yeah, fair enough - totally get that.  No worries.
Post by: chromium on February 16, 2016, 08:15:56 AM
Following the whole 'choke/filtering demystification' of yore, my EB-2D has the ability to render some very cutting sounds (of course that shrill little bridge pickup helps in that dept.).
Same goes for the '76 bird.  Wired up in parallel like a modern TBIV (as I received it), this one zings with the best of 'em.
Nothing wrong IMO with any of those stock pickups... but then again, I do like 'em with a little girth.  I feel that the mud connotation had more to do with their implementation(s).
Post by: Dave W on February 16, 2016, 09:14:01 PM
I'm wondering now if there are different Epiphone mudbuckers. Mine came from a bolt-on EB0; the cheapest Epi on the market. It might be a different pickup in the set-neck EB-3s, or the Elitist (sp?) models? ....
I thought the Elitist had US pickups. Should be the same TB Plus version as on the SG Bass.
I meant 2K. Gibson did something with the mudbucker in the late 70s and continued with the Epi reissues. Not sure what, but that's about what they read. They sound quite a bit different from the originals.
Take a look at this guy's meter readings.
https://www.youtube.com/watch?v=XtbazDu9Srk
Post by: Alanko on February 17, 2016, 03:23:55 AM
Alright, thanks for setting me straight! If I get a minute tonight I will inspect my Epi pickup.
Post by: dadagoboi on February 17, 2016, 04:46:08 AM
FWIW, the Novak 'Fatbucker' had the same narrow spacing as the Allparts Epi replacement pup I A-B'd it with.  And the covers were identical.  When I first started following Novak's stuff on his website he typically used components (bobbins, covers, magnets, etc.) that were in the marketplace.  At the time he developed his DS clone that was not an option.
I wasn't aware that the Artec has a wide stance.
Post by: Dave W on February 17, 2016, 02:47:32 PM
He built his first fatbucker for a customer to replace a Gibson original. Naturally it will have the same string spacing, since the Epis follow the Gibson. But it's nothing like a mudbucker in construction anyway.
It's the Senator Larry Craig signature model.
Post by: shadowcastaz on February 24, 2016, 10:10:09 PM
Sooooo I guess the only  referral was to Novak? This kinda ran away from me .
