The Moog died back in '87 and the replacement cost (through the then authorised repairs/spares group in the UK) was £125 - they had three PCB's and they were the only ones known to be in the UK at the time... pass...
Mind you, mine's already about a 1lb lighter than most already, for other reasons...
(that's why Scott and myself have
twin-sons-of-different-mothers syndrome - ie causing un/necessary mutilation to instruments in the cause of
function-over-form - simples...!)
Hollowbody indeed my Grecian buddy...
The fin I planned has (sort-of) changed as the cost went out the window - not available as a rattle and as I want to do this myself... crazy part is that, in theory, the three-part fin can be done in a day - base coats - something in the middle - top coats - 10 minutes between each application - if it all goes well it should be pretty cool...
I may just fit the single pup but fit controls for the sake of futureproofing - there's a bit of me going with the bridge pup (where it was prior to strip) but I'm leaning more towards the neck position now... opinions...?
Final plan is to strip out the contents of the 20/20 pup Tony supplied ages back and slot in an EMG I have for the bridge slot...
