Author Topic: i need some help gang - Colby Bass  (Read 109561 times)
Freuds_Cat
« Reply #435 on: April 28, 2011, 04:40:34 AM »
Been out with a lot of carnivorous girls, never considered becoming a vegetarian though. Maybe I need to rethink this situation  ;) ;D
Digresion our specialty!
« Reply #436 on: April 28, 2011, 04:39:00 PM »
 :o
« Reply #437 on: April 30, 2011, 02:27:08 PM »
Work stopage, daughter in town for the weekend.  Back later..............
« Reply #438 on: May 04, 2011, 06:34:49 AM »
OK, back in the saddle.  Will sand filler and finish control plate tonight.  Might even glue the neck in too!
« Reply #439 on: May 04, 2011, 06:39:20 AM »
 ;D ;D ;D ;D
« Reply #440 on: May 04, 2011, 08:32:55 AM »
;D ;D ;D ;D
Man, I'm feeling so out of it.  Sorry it's been such a long hiatus.
« Reply #441 on: May 04, 2011, 10:34:40 AM »
take all the time you need. happy builders make happy basses. ;D ;D
« Reply #442 on: May 04, 2011, 04:29:39 PM »
Here ya go!  Filler is sanded.  Neck doweled and glued on.  Control plate cut and drilled.  Gonna have to rout out the control cavity a little more.  The pot shafts are too tall (using your vintage harness) and will need some washers on the back to drop them down a quarter inch or so.
Will plane the fret board a little thinnner and install the frets this weekend.  Then, install the truss rod and glue the board onto the neck.
Then we start thinking about some S&S and top coats............
« Reply #443 on: May 05, 2011, 08:23:25 AM »
Take it to Walnut if you have to.
« Reply #444 on: May 05, 2011, 12:07:55 PM »
Shouldn't have to go that far!  Just a little more ash, that's all.
shadowcastaz
« Reply #445 on: May 05, 2011, 01:04:34 PM »
....I never minded a little more ash! :mrgreen:
« Reply #446 on: May 06, 2011, 05:23:42 AM »
You got it!  Neck set and control panel/plate are finished.  It will be a fret board weekend!
BTW, I really like the way the doweled neck came out.  I think I'm gonna use that technique on my own builds in the future.
« Reply #447 on: May 06, 2011, 08:16:55 AM »
that neck joint looks super!
the graining in the fretboard should compliment the colors in the top body plate very nicely as well as blend with the Ebony, Walnut and black.
i'm loving that hockey stick head even on the LP shaped body= it is small, light, practical and the almost "J" profile on that Epi neck will make it very fast. all 22 frets on that Martin fretboard should be very accessible.
could you take a snap with the fretboard layed on and the pup turned around?
« Last Edit: May 06, 2011, 09:03:34 AM by sniper »
« Reply #448 on: May 06, 2011, 10:48:09 AM »
Here ya go.................
The board will overhang the end of the neck by about 1/8".  I decided to leave it square on the ends, I like the look much better and the final fret will fit and work better IMHO.
« Reply #449 on: May 06, 2011, 11:29:38 AM »
i like the look of the pole placement better this way, good call on the square end fretboard.
