Poll
What color should the SS TB be???
Vintage white
6 (27.3%)
Sonic blue
4 (18.2%)
Dakota red
3 (13.6%)
Surf green
5 (22.7%)
Arctic white
0 (0%)
Black
0 (0%)
CANDY APPLE RED
4 (18.2%)
Total Members Voted: 22
Author Topic: NR TB project  (Read 12617 times)
Re: NR TB project
« Reply #75 on: January 14, 2016, 12:52:30 AM »
 :popcorn:
Re: NR TB project
« Reply #76 on: January 14, 2016, 06:10:27 AM »
The single pickup look is very cool
Re: NR TB project
« Reply #77 on: January 14, 2016, 07:53:06 AM »
I agree on the single look. So maybe a new pick guard and the one pup mounted closer to the heel.  When I pluck the strings up there instead of over the current pup, the does improve to my ears.  Just a thought......
Re: NR TB project
« Reply #78 on: January 14, 2016, 09:27:44 PM »
Just because it sounds better to you to pluck there doesn't mean that a pickup there will make the bass sound better. A second pickup always results in some phase cancellation of upper harmonics. That's not necessarily bad, but it does change the tone. That's why I wondered why you would add a pickup if you like the tone as-is.
Your bass, your choice, of course. If it doesn't work out, you can always use the empty pickup cavity to store a plug of your favorite chewing tobacco.  ;D
Re: NR TB project
« Reply #79 on: January 15, 2016, 06:21:21 AM »
Another reason to learn to rest your thumb on the lowest string, rather than the pickup.  Then all basses pretty much play the same.
« Last Edit: January 15, 2016, 04:27:40 PM by patman »
Re: NR TB project
« Reply #80 on: January 15, 2016, 07:46:53 AM »
i needed a thumb rest to play anything. then i got my abg and learned to play with my thumb resting on the e string. in my case having my hand closer to all the strings makes it much easier to play, especially with arthritis in my hands and fingers. this is the old man solution. :o
Re: NR TB project
« Reply #81 on: January 15, 2016, 07:47:49 PM »
All good suggestions.  Actually, the bass sounds better through my old B-15 than my Mesa.  I think I need to tweak the EQ more and maybe add some compression.  We'll see at next practice.
