I've played lots of long scale Bullets but I don't remember trying any shorties. On the long scale models, the pickups are too thin and midrangey because the longer scale has more harmonics, and would ironically, benefit from compression.
BTW, I never said that loudness wars were bass motivated; I was just weighing in on what had demonstrated itself to be a misunderstood subject. I think we'll be stuck with loudness wars until a lossless audio data compression format replaces .mp3, which in addition to shrinking audio file data size, has been shown to dramatically increase total harmonic distortion in the audio stream; not only is an .mp3 acoustically louder than an equivalent voltage uncompressed audio file, the distortion it causes is in the bandwidth where the human ear is most sensitive, causing hearing damage. The more the file is compressed, the worse it sounds and the more harmful it is to hearing. Instead of radio, which is all but dead now, jacking up volume to get attention on the airwaves like in the 90's, commercial .mp3's are separately mastered for maximum volume because the format itself causes hearing damage, even at low volume. Until pop music ears no longer expect blaring upper mids and icepick highs, popular music will continue to be overlimited.
On a related side note, I want to find every network who runs "reality programming" based around women and sidechain a de-esser (an upper midrange bandwidth-limited compressor) set to -30dB. It seems that every wannabe "attractive" female on television has decided that sounding like a snake with a tongue piercing is "sexy."
