Author Topic: Blueprints/measurements of 20/20  (Read 22710 times)
tore00
  • Southern by grace of God
    • Snakebite
Re: Blueprints/measurements of 20/20
« Reply #60 on: February 03, 2018, 03:03:13 PM »
After rehearsing the 20/20 hybrid of my own, I realized that the EMG pickup located at the center is almost useless. When i play together with the two Gibson pickups it disappears. Since my ears have never been particularly keen, I asked and got  confirmation that was not only my guess. In the next few days I will disconnect the EMG HB and trace a new pickguard.
« Last Edit: February 04, 2018, 01:48:40 AM by tore00 »
« Reply #61 on: February 04, 2018, 01:39:15 AM »
Have you checked if it is a phase related problem? Maybe the pickup is fine, just not wired right.
tore00
    • Snakebite
« Reply #62 on: February 04, 2018, 01:46:31 AM »
Yes, I did. And I discovered that the two Gibson pickups (that are actually are both neck ones so should be identical) are out of phase. If I play as they are they play very weak. I installed a EMG phase inverter and got a thunderous sound
tore00
    • Snakebite
« Reply #63 on: February 17, 2018, 02:17:09 PM »
Strange things are taking shape after few hours in the basement
Very rough now. I just scored an EMG HB on ebay that is the perfect candidate for a Ferrari Red.
  • Low Impedance LP's
« Reply #64 on: February 17, 2018, 06:07:41 PM »
Finding another neck seems less likely than winning the lotto........... But you never know! I still have a hard time believing that the one I picked up was unearthed........... And with the same serial number with the exception of the last digit! (which I stamped). It just goes to show you that if you watch long enough, anything is likely to show up.
tore00
    • Snakebite
« Reply #65 on: February 17, 2018, 11:35:06 PM »
Actually I am looking for a 24 frets and reshaping the headstock. Any idea about how to make the writing on the horn? I used a decal but was not fully satisfied
« Reply #66 on: February 18, 2018, 07:40:10 AM »
Weren't the transfers that Gibson used for the headstocks that didn't have MOP inlays very thin?
« Reply #67 on: February 18, 2018, 03:15:33 PM »
Aren't all waterslide decal transfers very thin?
tore00
    • Snakebite
« Reply #68 on: February 18, 2018, 11:18:29 PM »
The problem with thin decals is that they are almost transparent if printed in yellow and almost indistinguishable
« Reply #69 on: February 20, 2018, 03:02:55 PM »
It shouldn't be yellow, but gold.
Rothko & Frost can make it for you.
tore00
    • Snakebite
« Reply #70 on: March 12, 2018, 03:40:12 PM »
Now looking for the neck for my second 20/20 clone. The 24 frets candidates are quite few. There are some at ebay
https://www.ebay.it/itm/24-Fret-4-String-Rosewood-Maple-Electric-Bass-Neck-Replacement-Satin-Finish/302431429553?hash=item466a5163b1:g:jPMAAOSwr6RZpL8b
https://www.ebay.it/itm/24-fret-rosewood-fingerboard-2-2-tuner-holes-4-string-maple-bass-neck/273056570320?hash=item3f93709bd0:g:4EEAAOSwrDBZasjM
https://www.ebay.it/itm/New-24-fret-rosewood-fingerboard-2-2-tuner-holes-4-string-maple-bass-neck/323025745615?hash=item4b35d5b6cf:g:aD8AAOSwlyJaF5K9
None of them is perfect: truss rod is at headstock, holes mst be filled before shaping headstock, first has no dots and last fret looks strange and has angled headstock.
I could think of buying a 20 or 21 frets paddled neck but it looks to me not in line with overall concept of 20/20
What do you suggest to me? I think that best option is the first that I listed, Warwick style, to which I can fill the holes and reshape the headstock. Suggestions are welcome
tore00
    • Snakebite
« Reply #71 on: April 11, 2018, 02:00:40 PM »
I scored a nice Fernandes neck on ebay at a cheap price and ordered a bridge and pickguard blank. Everything in on route for my second 20/20 clone. I know that there is at least one who owns two 20/20s but I bet that there is not another that has two clones :mrgreen:
« Reply #72 on: April 14, 2018, 12:14:59 PM »
tore00
    • Snakebite
« Reply #73 on: May 10, 2018, 01:26:00 PM »
The neck arrived safely from Japan. It is very nice with no wear at all. It looks a little bowed downward but the trussrod is functional and string tension will probably put it in place.
Now I have to fill the tuners holes. What do you suggest? I was thinking to put some plugs the same size of the holes with wood glue, before cutting the 20/20 shaped headstock and paint it Ferrari Red back and black front
« Reply #74 on: May 10, 2018, 07:37:47 PM »
Plugs are fine but don't cut them from end grain. You want the grain running the same direction as the headstock.
