Author Topic: intermittent buzz  (Read 600 times)
intermittent buzz
« on: March 12, 2015, 07:08:34 AM »
I have a bass that has developed an electronic  buzz that goes away when I'm in contact with the strings, Ive had a look inside but cant see any obvious loose wires, its an active single pickup.
 any ideas what might be causing it?
Re: intermittent buzz
« Reply #1 on: March 12, 2015, 07:41:43 AM »
A quick check could involve opening the cavity, and  move wires with something pointy whilst being connected to an amplifier.
This sometimes isolates the problem, if there is a loose connection or something. The wires to the jack is common, cut off 5mm or something and re solder. If still buzz, re solder all connections - checking the wires with a diode tester for continuety as well.
If it's still buzzing, you might have to check each component thoroughly.
Of course you have tried to replace/tested you instrument cable first.. 8)
