Author Topic: Mesa 400 tube recommendations  (Read 7129 times)
georgestrings
« on: December 16, 2014, 04:30:41 AM »
I have a Mesa 400 on it's way to me, and am considering tube options - it already has 6l6s in it, but I'm pretty sure I want to put kt88s in it, instead... The preamp tubes will probably be left alone, unless there's an issue with them...
Any thoughts???
   - georgestrings
Re: Mesa 400 tube recommendations
« Reply #1 on: December 16, 2014, 05:01:58 AM »
PBG and others much more technical than I will surely reply, but swapping 6L6s for KT88s is a sometimes you win, sometimes you lose thing. Some amps handle it just fine, sometimes you put a lot of stress on your transformer. I would see how it sounds as is for a while.
georgestrings
« Reply #2 on: December 16, 2014, 05:16:34 AM »
Yeah, I'm definitely looking forward to PBG's thoughts on the matter... My research (so far) says that the Mesa 400 was originally designed to run 6550s, and that the use of 6l6s in them was due to the lack of a reliable source for 6550s *at the time* - which resulted in a slight downgrade in power, and different musical characteristics... I also haven't discounted going with 6550s, FWIW...
Thanks for your input,
   - georgestrings
« Reply #3 on: December 16, 2014, 07:25:22 AM »
I'll just chime in here until PBG posts..
Just curious, what kind of upgrade are you after, soundwise?
I have not used a mesa 400 since 1993, and I did not experiment with tube swapping during the time i played it.
Usually, when people upgrade to 6550 or KT88's, it's usually because they want more clean headroom.
If they just want a somewhat different sound, they might experiment with different manufacturer of the same tube.
In many cases, they end up spending a lot of money (KT's are expensive - at least here in Europe) for not quite the
most impressing results. More often than not, a 'stock' amp sounds best with the tubes it was designed for, if it is serviced/set up/biased correctly. I see many cases where owners have worn out 2-3 different sets of output tubes, with the original driver tube still in. So the ouput stage may not work properly with any output tubes.
That said, there is no reason not to experiment, but I'd check that the power supply and output trannies can handle the tube, and of course check that there is enough negative supply available, and that you will not exceed the total current draw the unit was designed for.
Perhaps not the answers you want, but I'm sure someone here have tried this and can post something on how it sounds :)
« Reply #4 on: December 16, 2014, 08:57:02 AM »
Is it a 400, or a 400+? The original 400 ran (6) 6550, while the "+" ran (12) 6L6.
georgestrings
« Reply #5 on: December 16, 2014, 10:42:21 AM »
I'm definitely looking for more clean headroom, which a change from 6l6s to 6550 or kt88s will provide, according to all accounts I've read thus far... Also, AFAIK the 400 WAS originally designed to run 6550s - so I doubt that'll be a problem... I also know of several people that are running kt88s in their 400s with excellent results - but I believe they had bias pots installed...
At any rate, I appreciate your contribution..
    - georgestrings
georgestrings
« Reply #6 on: December 16, 2014, 10:47:59 AM »
It's a 400, not a 400+... and as you say, the 400 originally ran 6550 power tubes...
     - georgestrings
« Reply #7 on: December 18, 2014, 05:06:16 AM »
For a bit more clean headroom with 6L6s you could try a set of JJ Teslas or whatever they are called now. I have done side by side comparisons between JJs , old Motorolas and Winged Cs. The clean headroom winner was definitely the JJ Tesla. Warm low end break up was a tie between the other two. If I was retubing a guitar amp I would probably go with the Winged C or old Motorola(if you could find them). For a bass, JJs would be my choice.
georgestrings
« Reply #8 on: December 18, 2014, 08:41:40 PM »
Thanks for weighing in...
   - georgestrings
« Reply #9 on: December 19, 2014, 02:08:00 AM »
And while you're at it, ask your supplier for a strong set! When shopping matched sextets or octets of tubes, there are not always much to choose from. But if your supplier/shop is kind, let them pick a strong set for you. Either brand (and I point to the WC/JJ comparsion here) can have early or late breakup. Yes, there are differences between tubes, but a working tube can be weak or strong. A/B tests (in my ears/opinion) of tubes/breakup is only ever valuable if they are equally strong (within reason). That said, even as a WC endorsee, I say thumbs up for JJ too - good and reliable for the most part!
« Reply #10 on: December 24, 2014, 08:28:55 PM »
Change the driver tube from a 12AX7 to a 12AU7 if you find you need more headroom. It will lower the overall gain of the amp a bit, but that trade will give you more useable volume and headroom. I'd also go with 6550's or KT88's, whichever you can find the cheapest. Mesa output sections are designed for lots of distortion and "dirty" power and tend to be a bit muddy but their preamps are very bright and high gain. Any of the big beam tetrodes, 6550's/KT88's, are going to have lower plate impedance which will shift the tonal balance even further towards lows, but in the case of the Mesa amps, it increases low-end extension and rolls off the highs just barely inside the range of human hearing. The 400 was designed around GE 6550A's, which is what all modern 6550's copy. It's a 200 watt amp, but it's good sounding 200 watt amp. I'm using a 400+ right now with a 12AU7 driver and while it will never have the punch of a beefier tube amp, it is a nice flavor tonally that cannot be derived any other way.
Basically, Randall Smith took what he had learned about making guitar amps and translated it directly to bass amps. There's an interview with him in the new Bass Gear magazine about his design philosophy that confirms everything I have been speculating about Mesa's tube bass amp design philosophy for years. They're not my favorite, but they are distinctive.
georgestrings
« Reply #11 on: December 28, 2014, 04:45:36 PM »
Thanks for weighing in - I was hoping you would... I'm leaning towards a set of JJ KT88s from eurotubes, and having my amp guy bias them properly - although eurotubes state that their tube sets are a direct match for my amp, and no re-biasing is necessary... Any thoughts on that???
 I was already planning on trying the 12AU7 driver tube swap... Also, agreed that my 400 is quite bright - rolling off some highs will not be a bad thing for me... While the 400 isn't quite as powerful as an SVT-II(my other tube amp choice), it's much lighter - and I tend to prefer the Mesa sound over the Ampeg sound - so far, I'm fairly happy with my purchase...
    - georgestrings
« Reply #12 on: December 30, 2014, 11:25:58 AM »
Mesa's tube bass amps ARE basically slightly revoiced guitar amps from the ground up and it's easy enough to figure out what tube current disappations correlate to Mesa's "rating" system, and Mesa runs their power tubes very cold but does not drive them with power, but rather cascading voltage gain, hence the massive power distortion and bright sound. The best thing to do with the rating system is to ignore it. Tubes change in current output over their lifetime and many good tubes have been trashed that needed only a simple bias adjustment.
The preamp's coupling caps can be changed for better low end, (Mesa's preamp begins rolling off bass frequencies very steeply around 80 Hz - because they are guitar preamps.) but it ends up re-voicing the entire amp and changing all the tone controls and the end product is very "Fendery" which is where the circuit started out anyway. Have your tech install bias pots and bias the amp for maximum stable clean output. A good tech could add a negative feedback loop to the output transformer to get even more clean power out of it, but it's going to seriously alter the sound, much in the same way that the 12AU7 driver tube swap does. One positive to this however, is that if you DO go this route, it's an easy and completely reversible mod and using the 12AU7 will help to get the most out of the power section if you do. 12AU7's have a much higher plate current capacity than 12AX7's. That translates into more clean power to drive the output section. These are all things that will make the amp have much more punch and a better low end, but it will change the tonal character of the amp. IMO, that change is for the better, but lots of other folks feel otherwise.
Quote
Note that the changes I am recommending are going to make the amp sound more like the Ampeg, as it has more clean power on tap and was designed that way. With the 12AU7, the preamp voicing will be the same, complete with all the over-the-top gain, but the passive EQ center frequencies will change. The graphic EQ is separate s/s circuit and will be unaffected. The Master Volume knob will become much more useable, and the Volume controls will lose much of their "fuzz boxy-ness" and actually perform as advertised.
Just to give you an idea of what to expect, there's absolutely no harm in swapping back and forth between the 12AX7 driver and the 12AU7 without doing anything else to the amp, so you can literally A/B that part of the mod yourself. Let me know what you think about the changes in sound if you decide to try it. From what I remember on Talkbass before I was banned, everyone who tried the mod loved it, and then after I was banned, several "expert" critics emerged from the woodwork to 'refute' me. I doubt most, if any of them, even had a Mesa tube amp.
 My Mesa still sounds like a Mesa, but it has a bit more punch. However, the light weight is because the amps use relatively small power and output transformers and the amp will never be more than a 225 watt amp; it will just be a cleaner 225 watt amp with better lows. I think my preference for setting up my tube bass amps for the maximum potential is why my views on tube bass sound conflict with so many other folks' ideas; they're used to buzzy overdrive from cold tubes being driven with insufficient power. There IS a "danger" to what I do: you can't get away with using crap tubes, but aside from that, the only thing you will notice is a slightly physically hotter amp and power tube life of a couple fewer decades, so you may end up needing to change them if you gig every day...in about ten to twenty years.  8)
georgestrings
« Reply #13 on: December 31, 2014, 11:40:26 AM »
Thanks for the additional info, PBG - I really value your experience on this...
I'll be sure to post updates as I tweak this amp to best suit my use/tastes...
   - georgestrings
rockbobmel
    • Cooper Jones Band
« Reply #14 on: February 10, 2017, 04:34:39 PM »
Hi Physco.  Long time!  I finally came around to wanting a tube amp and found another one with 12 Wing "C" 6L6GC power tubes and 4 JJ 12AX7 pre.  I don't have a 12AU7 around but I tried a JAN 5751GE and a Sylvania ECC81 and I like the Sylvania better. It did calm the gain down a little and bass is better.
« Last Edit: February 10, 2017, 06:56:10 PM by rockbobmel »
