Author Topic: Lowe Shop Notes  (Read 98221 times)
« Reply #45 on: August 02, 2015, 08:38:56 PM »
So, things have been busy this weekend.
I had been waiting for a few piece to get out of paint, and now that they have, I'm going full-tilt.
Here's the latest gallery shot, and please note the black LSP and tobacco burst Ridler are both 32" scale:
« Last Edit: August 03, 2015, 08:36:40 PM by BeeTL »
« Reply #46 on: August 03, 2015, 02:00:35 PM »
Looking good...
« Reply #47 on: August 03, 2015, 07:26:34 PM »
I agree.
« Reply #48 on: August 03, 2015, 07:44:42 PM »
Thanks...I'm having fun!
As I said, this last weekend was very productive.
First, I started with assembling some wiring harnesses.
The pre-drilled assembly blocks work equally well for P, J, and T-style harnesses.
The signal wires get laid out first, then the grounds:
I use mil-spec D sub mini pins for my quick connects, and color-code the wires to the pickup placement; Red = Neck, Blue = Bridge:
« Reply #49 on: August 03, 2015, 07:45:23 PM »
Then I install the harness to the pickguard and mount the pickup, or tape it in place in the case of a Thunderbird pickup:
Note the Lollar Thunderbird 5 pickup, I believe this is among the first ones made:
« Reply #50 on: August 03, 2015, 07:45:59 PM »
Flip it over, line everything up, and drill the pickguard screws.
I leave the plastic in place except for where the controls are mounted.
I hate it when the plastic is left under the controls because it is impossible to remove:
« Reply #51 on: August 03, 2015, 07:46:36 PM »
I’m a fan of finding elegant solutions to simple problems, and here are two little tricks I’ve developed using O-rings from the plumbing section of the hardware store.
A #41 works perfectly as a bushing to fit Hipshot Licensed tuners to an import headstock, and a #7 adapts the SG-style switch hole in my control plate to accept a third pot or a jack:
Nice and tidy:
« Reply #52 on: August 03, 2015, 07:47:25 PM »
Ridler #1 getting wired up with Fralin Big Singles in a P90 cover with no holes.
I solder brass nuts on the dog-ear base plate, so now it’s height adjustable.
To my knowledge, these pickups are unique to my builds:
I lay the wires out within the cavity so friction keeps them in place.
On the LSP with Thunderbirds (P’Nobird?) I use a bit of electrical tape to hold the connection secure because the pickup gets moved around:
Ridler #2 getting wired up:
« Reply #53 on: August 03, 2015, 07:49:12 PM »
I use 8-32 EZ-Lok threaded inserts designed for metal to bolt my necks down.
Step one is marking the necks to be drilled.
I clamp the necks in place, mark with an awl, double-check the placement, then head to the drill press:
The clamp keeps the neck from rocking:
« Reply #54 on: August 03, 2015, 07:49:47 PM »
Once drilled, I tap the hole for a ¼-20 thread, then use a sacrificial insert to center a deeper hole into the maple for the bolts on my contour-heel necks.
Also, I clean the pink thread-lock off the insert and instead flood the hole in the neck with thin CA before inserting the sleeve:
« Last Edit: August 03, 2015, 08:20:57 PM by BeeTL »
    • Myspace page
« Reply #55 on: August 03, 2015, 08:17:29 PM »
Looking good!! Always interesting to see how all of the builders here work their magic!
« Reply #56 on: August 03, 2015, 08:25:06 PM »
Absolutely, and thanks!
I've learned so much over the years by participating on forums like this one, and I like to "give back" as much as I can.
There are a number of little details and tweaks that are unique to my builds, so if others find them interesting or useful, so much the better!
8)
« Reply #57 on: August 05, 2015, 03:20:17 PM »
Inspired by the legendary bassist's modifed Precision, with a little design input from ebassist's SmallEQ, behold the latest addition to the Lowe Guitars lineup, the CHIMERA Series LSP, or P'Nobird:
« Reply #58 on: August 06, 2015, 07:43:47 AM »
Nicely done!  I love the Hipshots, they are my favorites.
« Reply #59 on: August 06, 2015, 01:19:33 PM »
Nice!
