Okay....since I just learned about old Ric Bass truss rods that I had no idea about in another post.
Here is another related question.
I played old Hagstrom 8-string basses back in the early 80s....full time for a few years, as hard as that might be to comprehend
I eventualy ended up with FIVE of them...two full-time on stage, one back-up and two for parts, as things broke on the main ones.
I tended to snap the tiny saddles at the point where the setscrew help them on the bridge...and also wore out tuners.
Anyway.....one day I stopped in mu local music store to have an electrical problem repaired on one. While the tech had it, I said to throw a new set of strings on it. He said come back to pick it up tomorrow....
When I showed up and took it out of the case to try out, the string action was like a half inch off the fretboard up at the body end. I flipped out and asked "WTF did you do to my bass?" The store owner acted like it was a big surprise. He ended up telling me to leave the bass and his tech would look at it.
When I returned a couple days later, I was told they tried to adjust the truss rod with no luck. Then they tried to heat press the neck, again with no luck. They said it was a mystery and there was nothing they could do to repair it.
That bass was my main player or a few years. Custom trans blackburst finish..Billy Sheehan liked it so much he had the same shop make him a dupe! I still have it, for sentimental reasons but it unplayable. Before this incident, they action was the lowest of any bass I had owned. Played incredible. At one point I had put all new truss od nuts in all my Hag basses in the 80s. They were some mini metric slothead screws. I hunted down the correct size replacements but with hex heads because the slotheads tended to crack/strip. Those worked great for years,
Anyone ever have a similar problem with old Hagstrom Basses? I cannot imagine that huge aluminum T rod theyused int eh necks going bad, so the bass never got repaired. Sure would be great to finally make it playable again, just to pay it back for all the use I got out of it.
