Author Topic: Something is all wrong with this Paisley Telecaster Bass...  (Read 2293 times)
Re: Something is all wrong with this Paisley Telecaster Bass...
« Reply #1 on: December 21, 2013, 03:36:07 PM »
Yes it is.
It might be a legit paisley with the finish removed, but that "pink" is awfully dark for its age and condition. Might be a redo.
ack1961
« Reply #2 on: December 21, 2013, 05:34:11 PM »
looks like the wallpaper fairy ran out of material...
« Reply #3 on: December 21, 2013, 06:30:57 PM »
Kind of what I was thinking.
Bionic-Joe
« Reply #4 on: December 21, 2013, 08:12:06 PM »
looks like the edge was stripped
« Reply #5 on: December 21, 2013, 08:18:45 PM »
Doesn't look right - almost like someone did a "home brew" job on it.  Wasn't there someone here that was doing a wallpaper project?  Maybe it was someone over a ReRanch.
« Reply #6 on: December 22, 2013, 08:13:12 AM »
Refin or a ho...
« Reply #7 on: December 22, 2013, 06:58:31 PM »
Or a non-original bass done up a long time ago with wall paper out of grandma's kitchen.
pilgrim9
  • Jr. Member
« Reply #8 on: December 22, 2013, 07:32:17 PM »
Fender put the contact paper on and then sprayed the poly sanding sealer, gold paint on the sides of the body and over the straight cut edges of the paisley wallpaper, then cleared. This has had the clear & color coats striped but when they got to the poly sanding sealer they stopped. That poly sanding sealer has to be sanded off. The cracks in the poly go through the paisley and around to the sides so it seems like a legit paisley body. The lack of the gloss clear coat could explain the color difference also. The neck looks like a refinish, just no wear at all and if you have had climatic changes drastic enough to cause the cracks/checking on the body it sure should have had some effect on the neck finish.
If you push something hard enough it must fall over.
« Reply #9 on: December 22, 2013, 08:20:04 PM »
I'd assume that Fender bought sheets or rolls of the paisley material and used a template for the shape. Was the paper applied uniformly or rotated or shifted depending on who did the applying?
« Reply #10 on: December 31, 2013, 01:16:35 AM »
The paisley material was an off the shelf pre-pasted wallpaper made by a company called Stickum. It was available through wallpaper dealers and you could still find the Fender paisley and flower papers if you dug around into the early 80's, as it never sold.  The paper patterns were made to meet demand for mod hippie styles, and probably Fender was the biggest buyer.  There probably is some way to strip the paint off the sides and leave that clean edge, but I don't know how. But you could've dug up the paisley paper at one time.
