Author Topic: Straightening a bowed neck  (Read 2005 times)
ThunderBucker
« on: June 17, 2011, 05:48:41 PM »
My buddy Carlo sent me a Squire J neck to replace the cheap P bass neck on TestBass (the bass I cycle all the pickups I make through to test them out). That P bass neck plays like a splintery 2X4, except maybe not as good.
I was looking forward to a nicer neck, except the neck Carlo sent had a pronounced ski-slope about 5 frets from the nut.  Even tightening the truss rod to near infinity would barely take it out, and that was with no string tension.
So I remembered a trick I saw at Charvel's in Azusa in the late 70's, when it was in back of the strip club.  They had a jig where you could clamp a bowed neck straight, then put a heat lamp on it.  Kind of like steaming wood so that you can bend it.
I clamped my bowed neck to the workbench, with a shim so that I could actually reverse-bend it a little, and put a heat lamp on it (a chicken incubator, to be more exact).  I watched the temp with my IR temp sensor gun (don't want to set no fires or bubble no finish) and held it at about 190F for about 30 minutes.  Then I turned the heat off and let the neck cool in the clamped condition.
I took it out of the clamps, and wow, it was really straight!  Hard to take a picture of though...
Now it is ready to make its acquaintance with Mr TestBass.
« Last Edit: June 17, 2011, 06:18:01 PM by ThunderBucker »
Re: Straightening a bowed neck
« Reply #1 on: June 18, 2011, 04:21:12 AM »
Steve asked if I had a crappy jazz neck.  I certainly did, late '90s Korean Squier, not the only bad one I've seen.  I had adjusted the TR to the limit, the skunk stripe was breaking out of the back of the neck.  Cheap as I am, even this was a neck beyond salvaging or so I thought...I specifically remember him specifying 'crappy.'
Hope this works.  I have a few more to send him, including a Hondo P neck that I clamped into a 1 inch back bow for a few days but without the heat treatment.  No luck with that one.
« Reply #2 on: June 18, 2011, 07:05:49 AM »
Wait --- a badly bowed Squier neck? What a surprise!
It works sometimes, and sometimes it won't keep. That one sure does look straight, hope it stays that way.
« Reply #3 on: June 18, 2011, 09:24:25 AM »
Great technique.  Only time will tell if it holds.  Hope it does!  I've taken the stance that if I can plane/woodwork a slightly bowed neck into submission, I won't use heat unless it's irreplaceable.  It's always worth a try though!
