Author Topic: Hipshot D Tuner on LP standard  (Read 1095 times)
Geoffzilla
« on: February 08, 2008, 06:07:14 PM »
I just bought a hipshot detuner for use on my Les Paul bass.  The model was the GB7, which is made to match grover tuners.  Everything lines up, but the post is about a quarter inch too short.  Bummer!  It works, but its a little funky.  The post wobbles a bit, and I think the string windings might be catching because of it.
Has anyone successfully put a hipshot on their LP?  If so, was there a trick or did you use a different model?  Should I just call it a wash and use my tuner?
Thanks,
-Geoff
Re: Hipshot D Tuner on LP standard
« Reply #1 on: February 08, 2008, 08:12:13 PM »
I can see the problem with using mahogany which is soft. The constant use would loosen the screws i would assume
