Author Topic: Lap King? NR  (Read 2517 times)
66Atlas
Lap King? NR
« on: September 21, 2017, 10:18:17 AM »
Never heard of Lap King but looks like it was started by a former Hamer employee that builds Lap Steels.  It's a pretty cool take on a NR.
https://reverb.com/item/6613750-custom-lap-king-thunderbird-bass-non-reverse-style-by-jason-dumont
Re: Lap King? NR
« Reply #1 on: September 21, 2017, 11:01:45 AM »
Dead sexy.  Very well done.
Re: Lap King? NR
« Reply #2 on: September 21, 2017, 01:56:24 PM »
Gorgeous.
But a bit of a weird story about that headstock. Rosewood on back and front for strength?
Re: Lap King? NR
« Reply #3 on: September 21, 2017, 02:12:02 PM »
a little seller's hyperbole.
66Atlas
Re: Lap King? NR
« Reply #4 on: September 21, 2017, 05:11:09 PM »
3 piece quartersawn Korina with a volute should have been more than sufficiently strong indeed, but I like the look of the rosewood on the face as a feature.  A trans finish would have looked amazing I bet.
Re: Lap King? NR
« Reply #5 on: September 21, 2017, 07:07:05 PM »
Rosewood would definitely add stiffness to the headstock. Not sure why that would be necessary though.
Nice looking work.
Re: Lap King? NR
« Reply #6 on: September 22, 2017, 01:38:02 AM »
Definitely?
Rosewood has an open grain structure. If you use only a thin sheet of -let's say 2 mm- it'll be very vulnerable and brittle.
I have my doubts about the added strength.
Esthetic reasons I can understand.
Re: Lap King? NR
« Reply #7 on: September 22, 2017, 07:22:26 AM »
That's pretty sexy! Seems like a nice price too if you want a good quality non-rev.
Re: Lap King? NR
« Reply #8 on: September 22, 2017, 09:43:56 AM »
Definitely?
Grain structure has nothing to do with it. Depending on the particular species, rosewoods are 2 to 3 times stiffer than korina. Even a 2mm front and back overlay of rosewood would be stiffer than an all-korina headstock of the same total thickness.
I've seen back strap overlays of stiffer woods used in headstock repair. Some acoustic guitar luthiers do this routinely on new builds.
Re: Lap King? NR
« Reply #9 on: September 22, 2017, 11:43:07 PM »
Definitely?
Ebony is brittle as well when thin, but stiffens even in thinner sheets than 2mm. My project korina explorer bass headstock went from rubber soft to rock solid just by replacing the black plastic top sheet with ebony veneer. It's not brittle or vulnerable anymore when glued to the headstock wood.
Re: Lap King? NR
« Reply #10 on: October 04, 2017, 12:58:24 PM »
Being stiff and brittle is non-exclusive. A material can be both.
Re: Lap King? NR
« Reply #11 on: October 06, 2017, 08:33:47 PM »
True but irrelevant. Even a very brittle wood is not going to break from brittleness when it's glued to the face or back of a headstock. And rosewood isn't brittle.
Re: Lap King? NR
« Reply #12 on: October 10, 2017, 01:21:32 PM »
All that said, these days I find myself more brittle than stiff.  :-\
Re: Lap King? NR
« Reply #13 on: October 10, 2017, 09:57:38 PM »
You need to work on that. Emulate Hugh Hefner. He kept it up until the end (with medicinal help) and now he's eternally stiff.
Re: Lap King? NR
« Reply #14 on: October 11, 2017, 05:01:04 AM »
But I get a running nose from Viagra! Sniff to be stiff.  ;D
Hugh is a loss. In all his artficiality he was absolutely authentic. In any case, they only ordered him to heaven for the interviews.  8)
« Last Edit: October 11, 2017, 07:11:38 AM by uwe »
