Gear Discussion Forums
Bass Amps & Effects
(Moderator:
Tube retainers
Pages: [
Topic: Tube retainers (Read 1847 times)
Nighttrain1127
Newbie
Tube retainers
on:
May 01, 2017, 08:55:29 AM »
I have a Fender Bassman 300 PRO it currently has 6550's in it . I am changing them out for KT-88's soon. My Question is will the spring retainers that are currently in the amp work with the KT-88'S or do I need to order some Bear Trap type retainers?
Thanks in advance
Re: Tube retainers
Reply #1 on:
May 01, 2017, 10:02:01 PM »
You rarely see bear traps With KT88's because most of them have a flange at the bottom of the socket, as well as many of them have metal capped sockets.
If you have spring retainers designed to fit 6550's, they will most likely fit KT88's.
Moderator
Re: Tube retainers
Reply #2 on:
May 01, 2017, 11:02:19 PM »
+1
Nighttrain1127
Newbie
Re: Tube retainers
Reply #3 on:
May 02, 2017, 12:43:34 PM »
Thank you guys
Re: Tube retainers
Reply #4 on:
May 02, 2017, 10:03:56 PM »
Just a thought, check that there is room for KT88's. It's probably OK, but I've seen chassis designs that does not allow those sockets.
Last Edit: May 02, 2017, 10:10:52 PM by amptech
Pages: [
Bass Amps & Effects
(Moderator:
Tube retainers
