Author Topic: ? for the NR experts  (Read 4892 times)
Re: ? for the NR experts
« Reply #15 on: September 20, 2016, 11:39:32 AM »
   I think some of my birds have slot heads. Lemme check.
« Reply #16 on: September 21, 2016, 07:13:33 AM »
This confused me for a second. Slot head... bird.... What? Oh, the screws...  ;D
« Reply #17 on: September 21, 2016, 09:16:30 AM »
Slothead is spelled with an "o", not a "u", ok?!
« Reply #18 on: September 21, 2016, 06:42:06 PM »
Nice!
66Atlas
« Reply #19 on: October 11, 2016, 04:56:33 PM »
I had hoped that the case for my reissue NR would fit the '67 so i could have a safer case option for gigs.  Turns out the vintage bass is too long, does anyone know of a good modern alternative to the original case?  Mine 67 case is in pretty rough shape and doesn't offer much in the way of protection.
« Reply #20 on: October 12, 2016, 05:36:16 AM »
I converted an Epi Reverse case following Rob's (Basvarken) example.  There's enough room for a full sized Gibby headstock.  You just pull back the liner, remove the styro, flip it over, trim as necessary, and glue the liner back in...ish.
66Atlas
« Reply #21 on: October 13, 2016, 05:20:03 AM »
Ah, perfect and way cheaper than having something built!  I actually have an extra Gibson reverse TB case, I may play around with it and see if can do the same thing.
« Reply #22 on: October 13, 2016, 05:40:54 AM »
That should work, my Gibby cases are huge. I prefer the Epis, a lot easier to handle.
« Reply #23 on: October 13, 2016, 08:09:54 AM »
I briefly had an Epi Explorer, and the case was noticeably smaller than the 2013 Gibson I'd had previously. As a case designer of 20 years, I just don't get some of the things I see out there...
« Reply #24 on: October 13, 2016, 09:38:08 AM »
The current Epiphone Thunderbird case is a slightly different design. Trapezoid shaped.
One of my customers bought one last week for his BaCH Fenderbird.
But I do think the NR would still fit if you flip the interior like Carlo and I did.
« Reply #25 on: October 13, 2016, 10:02:25 AM »
The Bach 'Fenderbird' is about the same overall length as a modern Thunderbird, unlike the original JAE  FenderBird (and my replica) which is a few inches shorter due to the compact body.  My TBird style basses and I'm assuming the JAE original fit in a Fender Jazz sized case.
Because of that compactness they're less prone to neckdive than the 'lets just take a TBird body and stick a Fneder neck on it' basses.
The only off the shelf Explorer bass case currently on the market I know of is the Dean which leaves around five inches between the end of the headstock and the case.  Ungodly huge.
That's why my EBirds are priced with a gig bag instead of a case.  I've had three customers add the Dean case, the rest opt for the bag.  One of the three immediately bought a bag after receiving his bass.
