Gear Discussion Forums
Bill's Shop: Projects, Mods & Repairs
(Moderators:
Help! Ground issue Epiphone Blackbird
Pages: [
Topic: Help! Ground issue Epiphone Blackbird (Read 1099 times)
Moderator
Keep On Rock'n !
on:
June 02, 2016, 07:35:41 AM »
I have a touring pro's Epi Blackbird in the shop for a setup and solve a ground issue. The ground wire coming from the bridge looks like it was never soldered. I grounded it to the toggle switch and no hum comes from touching the bridge but I do get a faint hum when I touch the toggle switch. Anyone got a wiring diagram?
FrankieTbird
Re: Help! Ground issue Epiphone Blackbird
Reply #1 on:
June 02, 2016, 09:40:33 AM »
I don't know of a wiring diagram, but it really shouldn't matter where you ground the bridge, as long as everything is grounded to the output jack. Traditionally, the bridge wire is grounded to a pot case.
Moderator
Keep On Rock'n !
Reply #2 on:
June 02, 2016, 10:53:09 AM »
The Blackbird only has a toggle so I grounded to that, I should be ok then
Pages: [
(Moderators:
